Question about Vacuums
I have a minuteman c37115-14 MPV14 vacuum. When I turn it on the brush will rotate for a second or two and then it stops. The light indicates "brush is blocked". Any idea what my problem is? TY Mark
  • neo_want1 Mar 14, 2009
    I check the brushroller end cap and they are moving freely but the problem still happens
  • 32 Answers
Check your brush roll for string (from the carpet) or other debris in and or around the bearings on the ends of the brush roll. Or check your brush height. If you have the brush too low/close to the floor it drags the brush down, telling the circut board inside that the brush spin is restricted.
Brush rolls often get lint, carpet string, and dust accumulated at the ends around the bearings. Pull out your brush roll and you will be able to take the end caps off either by hand, or with a 3/8 inch nut driver. At this point you will be able to pull the shaft out of the brush roll, and clear the debris that could be inside. Your bearings may have gone bad by this point.. All of this is inexpensive to fix, and easy to do. If you have any questions, just drop me a line. I have this manual on my windows skydrive, so if you need that I can provide that also.
Posted on Jan 20, 2009
The brush roll works for a second than red light goes on and it stops. No obstructions to stop the rotation
First make sure that there is no threads wrapped around the roller brush at each end. Next place a couple drops of motor oil in the crack at each end of the roller brush to lubricate the bearings. Do not over oil or you will get oil on your carpet. Now try starting the vacuum on the kitchen floor.. If it still shuts off, then the motor windings are shorted out, meaning the motor is defective and needs replaced. If the vacuum cleaner costs about $ 100.00 , you would be better off buying a brand new vacuum cleaner, rather than replacing the motor.
Oct 12, 2015 | Shark Rotator Professional Lift-Away...
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Looking for part number 831238 1/6hp brush motor
Try these people:
http://www.michco.com/p-102421-minuteman-ambassador.aspx
1- 800-331-3339
CustServe@Michco.com
831238-2
Item On Page-7-8 Ref# 128
Qty Required-1
This item replaces part#(s): 831238
Apr 16, 2010 | Minuteman C46000-00 Self Contained Carpet...
How much is a brush motor? Is it easy to replace or am i better off buying a new minuteman?
A new Brush motor is $305.02
Try these people:
MOTOR, 1/6HP 120VDC X17 831238-2
Qty Required-1
  • 1-800-331-3339
  • Michigan Company Inc.
    2011 N. High St.
    Lansing, MI 48906
    Phone: (517) 484-9312 or 800-331-3339 US only Monday - Friday 8AM- 5PM EST Excluding National Holidays.
    FAX: 517-484-9836
    E-Mail: CustomerService@Michco.com
    Dec 30, 2009 | Minuteman C46000-00 Self Contained Carpet...
    Kenmore 116.23513301
    If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
    Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
    Brush motor not working
    If there is power to the motor then it should run. It could be the PCB, if you have power to it and not to the motor, then it is bad. Just start at the motor with a voltmeter and go from there to see where you are losing the voltage. Is the hose want pushed all of the way in the place that it goes? There is a safety switch on alot of this type of vacuum. The idea is so the brush roll won't turn when the hose is out and is upright.
    Feb 18, 2008 | Minuteman C37115-18 Dual Motor Upright...
    Vacuums Logo
    106 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
