Question about Ricoh Aficio AP410N Laser Printer
Restore settings ricoh aficio - Ricoh Aficio AP410N Laser Printer
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
  • 393 Answers
SOURCE: Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Posted on Jun 27, 2009
canontech
  • 1219 Answers
SOURCE: Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Posted on Jan 13, 2010
newport74
  • 58 Answers
SOURCE: how to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Posted on Feb 27, 2010
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
I can't set up scenner options in aficio mp2000
look here in Ricoh white papers you should be able to find what you need. http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Mar 16, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh aficio 1035 factory rest now unable to get into settings
Press the SNC raport and change /set the value default.
Dec 02, 2009 | Ricoh Aficio 1035 Copier
HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to reboot the ricoh aficio 1515mf. i could not use as all were password protected. how to erase all the password and memory??
To clear the memory (reboot) the RICOH AFICIO you will have to send it to the factory where they will wipe the memory and restore the machine to its defaults.
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh Aficio AP410N Laser Printer Logo
16 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
