Question about Fellowes Manufacturing Powershred C-220 Shredder
The "bin full" keeps on coming on
Whenever I try to shred anything on my Fellowes Powershred C220 the red light comes on saying the bin is full when it's not. Sometimes I will be in the middle of shredding something and it will stop and the red light meaning the "bin is full" will come on and I have to continuously shut off and on the machine in order to continue shredding.
  • Anonymous Mar 26, 2009
    well, if its the same problem, why do i need to retype it.
    However, the bin full light comes on, as soon as turning on the machine, even without shredding anything.even with no bin in there.
  • 215 Answers
First off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Posted on Apr 15, 2009
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
Fellows Powershred c-120 c indicator lights
your bin full sensors are dirty or broken to clean access bottom side of shredder head and look for a set of screws on each end of the paper throat. There you will see two little bulbs (bin full sensors) these have more than likely gathered paper dust and need to be cleaned with a Q-tip dipped in a little Isopryl Alchohol. This should solve your problem. If you have any questions just call us at 1-800-945-4545. A Customer Service Representative will assist you.
Apr 22, 2008 | Fellowes Powershred 120C-2 Shredder
Power switch problem
It sounds as if your Bin full sensors are dirty and need to be cleaned. You should contact Fellowes at 1-800-945-4545.
Jan 15, 2008 | Fellowes Powershred 420 Shredder
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Fellowes Manufacturing Powershred  C-220 Shredder Logo
1,658 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
