Question about LG TROMM 4.0 Cu. Ft. Front Load Steam Washer
Lg tromm front load washer power button stuck
Button stuck
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
How do I replace a faulty on/0ff button
How to fix a stuck or broken On/Off button on a GSM/AT&T ...
www.imore.com/how-diy-repair-stuck-power-button-gsmatt-iphone-4
Jul 31, 2012 - If you have a GSM/AT&T iPhone 4 with a On/Off button that's stuck,broken, collapsed, or otherwise non-functional, and you don't have ...
Oct 26, 2015 | Cars & Trucks
Film rewind button at the bottom of the camera stuck on the "in" position. Cannot get it to release.
Put the camera in a change bag open it then manually rewind the film. From there you may be able to free the button. If the button continues to be stuck here is something worth trying that I have seen others do with stuck buttons and aperture blades. To the button add a few drops of lighter fluid let it soak in. Sounds crazy yes, however sometimes that will dissolve gunk buildup freeing the button. That trick works wonders on stuck aperture blades; actually a common practice at repair shops.
May 27, 2015 | Photography
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
2003 GRand Prix, the 3rd brake light works , replaced bulbs and fuse under brake pedal, brake lights still don't work, any ideas?
The button is stuck in? Which button? If it is the flasher button then I would think that is why the brake lights and the flashers don't work. If it is the button behind the brake pedal that is stuck in it should keep the brake lights on and that would stop the flashers from working. I need more clarification on which button you are talking about being stuck.
Oct 16, 2014 | 2003 Pontiac Grand Prix
Lg tromm washing machine
If the machine still works and that is the only problem I would use it till it doesn't, really they cost so much to fix sometimes
Sep 01, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Keurig power button
I am not familiar with the button itself but I am familiar with stuck buttons. If this is an analog (push down button then is most likely stuck in cover or housing. For this you can use a pin or small screwdriver and gently pry it back out from the side it is stuck on. If this is a digital (touch button) then you will most likely have to replace the board it is on. One thing you can do is take it apart, unplug the board the button is on, leave it for a few seconds and plug it back in. That might reset this.
Jul 12, 2014 | Keurig Vue Brewing System
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The Stat button is stuck down, have tried popping up with a paper clip but no good. Any suggestions, none of the other buttons will work with the STAT button stuck!
Hi
take out all 4 batteries take alcohol 2 drops on the button
push the button a few times it should help unless there is glue inside than yo must open the calc and clean all the buttons
Sep 12, 2012 | Texas Instruments TI-83 Plus Calculator
LG TROMM 4.0 Cu. Ft. Front Load Steam Washer Logo
305 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
