Mitsubishi electric kerosene heater shows 0f error and it shut down
  • 126 Answers
SOURCE: we have a monitor 2400
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 19, 2009
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
  • 4 Answers
SOURCE: MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Posted on Dec 31, 2009
  • 69 Answers
SOURCE: i have a master 150000 btu kerosene direct fire
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Posted on Dec 10, 2010
Heater comes on and then shuts down after a few seconds
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 16, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Runs about 5 minutes and shuts down but you can restart it with several trys
heatman101
Dec 30, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My heater keeps shutting down. Just put fuel in. Lights and runs about 5 seconds
heatman101
Dec 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Shuts down after about 30 seconds, blowing some smoke.
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My electric Kerosene heater will shut off
You need to do a little maintenance. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to get your unit running like new. Most portable heater parts are the same. Also DESA went into bankruptcy but many dealers still sell parts. It is all in my tip. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 28, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Was running fine, then shut off and smoked like out of fuel.
THERE ARE THREE OR FOUR REASONS FOR THIS. DIRTY FUEL FILTER, FUEL PRESSURE INCORRECT, DIRTY AIR AND LINT FILTER, THE ELECTRIC EYE THAT SEES THE FLAME IS BAD, OR THE CONTROL BOARD IS BAD. THESE ARE MANUFACTURED BY MESA OUT OF BOWLING GREEN, KY AND THEY HAVE A WEBSITE. I GOT MY NEW PARTS AT MY LOCAL RURAL KING STORE.
Jan 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Htr shuts off after awhile and won't come back on till it's cooled down
I believe your heater has a solid state relay to start the motor when the motor gets to speed it is supposed to shut off. It may be stuck in the on position.
Jan 20, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
213 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
