Net is not connected with blue solel (bluetooth)
Tried to connect with four Diffrent Mobile Sets but failed
How i make my head phone blu sol work
Posted on Apr 02, 2009
Can I connect bose speaker to Sony blue ray via blue tooth
Is your Bose speaker a Bluetooth speaker ? Does your Sony blue ray player have Bluetooth ? You can connect the two only if Both are Bluetooth devices.
Feb 15, 2015 | Sony Televison & Video
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Unable to connect my pc to 5800 for internect by blue tooth . do i need blue tooth modem on my comp
yes , n the name of the device is bluetooth dongle which can b easily connected through USB port and also u will get driver with tht dongle just intall it n thn connect ur phone .
secondly if ur question is u want to get internet access in ur mobile from pc then u must hv wifi modem of internet.
also u can access net in your mobile by using a software Gnubox and mRouter and bluetooth dongle in ur pc
hv fun
Mar 14, 2010 | Nokia 5800 XpressMusic Smartphone
Not working Bluetooth in my Samsung Mobile Model No.SGH-X820
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first.
if this too fails then the blue tooth hardware/software has to be rectified.
Sep 20, 2009 | Samsung SGH-X820 Phone
Bluetooth
On most phones, you'll go to: Settings > Connectivity > Bluetooth > (turn on) > Phone visibility (shown to all / on) > Search for devices >Choose headset (when located) >>
The password is 0000 (four zeros)
I don't have the link for the Super tooth II manual. but here's the link for the Supertooth One manual: (it may help)
http://www.supertooth.net/img/one/mdp_EN.pdf
You'll need Adobe reader to view it. It's free. Download here if you need it:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Nov 07, 2008 | Blueant Blue Ant 091193 Supertooth II...
Motorolla H350 with Nokia N80
You can reset any bluetooth headset by pressing the volume key and the power key pressing them simultaneously for few seconds and it will be resetted. TO connect with any other bluetooth mobile press the Power button of your headset while your mobile searches for bluetooth headset. when it asks for a pass key use 0000. now you can get connected. try this...........
Sep 23, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
