I need manual to operate washing mechine wash and dry 3120 siemens
  • 16 Answers
SOURCE: washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Posted on Mar 15, 2007
SOURCE: LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Posted on Jul 12, 2008
SOURCE: operation manual for GE washing machine
I got a GE washer won't washer or spin.
Posted on Jan 11, 2009
  • 13 Answers
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Posted on Jul 17, 2009
  • 414 Answers
SOURCE: siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Posted on Nov 26, 2011
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Manual 3120
cheaper to buy a complete bearing kit
Feb 05, 2014 | Siemens Washing Machines
Dear my washing machine is product from italy made siemens wash and dry its showing E14 errorr please advise me what i can atcvally
Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book.
Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens Washing Machines
The drum have stopped going around. Is it worth repairing?
washing mechine wont spin or drum stopped going around .siemans xli1240
Aug 16, 2011 | Siemens WXLP1460 Front Load
HOW DO YOU START A SIEMENS WASH & DRY MODEL 12D52
Methinks you could do with a manual for your washer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 01, 2011 | Siemens WIQ1633 Front Load Washer
Siemens washer dryer model WD12D520GB, what is error code 17?
i think f17 is the code for low water pressure, check the water supply to the machine is turned on and the hose is not blocked or kinked or pinched
Jan 14, 2011 | Siemens Dryers
Drain pump for Kenmore Elite top loading washing mechine
This will not be in the owner's manual.
If you search inside the cavity of your washer, however, you will find the service manual taped to the wall in a plastic bag.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Manual for siemens 3120
washer wont empty of water
Jul 03, 2009 | Siemens Washing Machines
Washing Machines Logo
Top Washing Machines Experts
