Philips CD250 No Basis
When somebody calls me than the phone rings ,I pick up the phone and than the ringing stops and the display blanks. I have resetted the phone and did the starting procedure but than the displays shows Searching and finally NO Basis . thks for your help...rgds...don
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
Your caller id log is full, you can fix your phone by pressing the Calls button, then the delete button over and over until it is empty. This will fix your problem without deleting all your programming.
Posted on Feb 10, 2008
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
  • 19 Answers
SOURCE: Searching
you have a problem on the signal of your phone find a good location
Posted on Jul 16, 2008
  • 28 Answers
SOURCE: Lights up but doesn't display anything but horizontal lines
A few things to try... Get another ipod and back up (using the menu button) to the first menu list you can,( should show the Music, Movies, ect list) and then do the same to your broken ipod. Follow the good ipod with the broken ipod and open a song. (just to clarify, you are using the good ipod to know what to press in the broken ipod because you can't see the screen). Now use your headphones to see if it is playing. If it works, your LCD is dead or depixelated. A screen replacement is necessary. You can find one on eBay for around $25 or someone to do it for you possibly on Craigslist.
If this doesn't work and it doesn't sync right to your computer then *********** board may be the culprite. Unfortunately this is the second most expensive part to replace. If you don't want to deal with it sell it on eBay/craigslist and put the money towards a new one.
Posted on Jan 02, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: changed battery on mp3 player, now ican't get it to reset
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
Nokia N8 problem. When making and receiving calls the screen go blank if in sun or when your hand is in front. when it is ringing and you pick it up its goes blank you cant see who is calling, it only...
You don't have to worry about this, actually there is a sensor in Nokia N8 which senses the heat of your body so that when your ear is touched with your phone during a phone call, the screen is automatically locked so that no button is touched or clicked accidently when your phone is touched with your ear; it is just due to the sensitivity of the touchscreen display.
Jul 22, 2011 | Cell Phones
I have a SFX-11 fax machine. When I received a fax this morning and it stopped in half way. the screen shows nothing, but the handset (phone) is ok.
Stopping in the middle of receiving a fax and the display going blank is a good indication that the circuit stopped functioning.
Try dialing out and you should hear the beeps as you press the buttons.
Or ask somebody to call you to see if it rings or not.
The rest is obvious. :)
Apr 01, 2011 | Office Equipment & Supplies
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
How to know an incoming phone call from fax
The display will not be able to tell you what type of call is coming into the machine, however you can subscribe to a feature called `Smart Ring`from your telephone company, this will give you a second number on your line and will cause the line to ring in a distinctive pattern.
That is the only way you will be able to tell other than picking up the receiver.
May 27, 2009 | Philips Magic3Voice PPF585 Printer
Disconnecting in-coming call
You must either pick up the receiver or let it ring. Pressing "Mute" only hides yous voice from the other person.
Mar 13, 2009 | Philips CD4451S/05 Phone
KX-T7730 Picking up Problem
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Nov 18, 2008 | Panasonic KX-TA308 Phone
Panasonic KX-TCD650E
Possibly switched off and needs recharging? Press the button with the picture of the red phone next to it for a few seconds. The phone shoud beep and the lcd should come on. You may now need to put it on charge ( you will see the battery on the lcd 'charging') Hope this helps
Jul 13, 2007 | Panasonic KX TCD650E Cordless Phone
15 people viewed this question
 Grubhead
Grubhead
