Question about Food Mixers
R.P. JONCK: MY KENWOOD KM 264 STOPS COMPLETELY. I CHECKED ALL THE SWITCHES AND FUSES BUT I CAN'T TEST THE CONTROLLER UNIT. WHERE DO YOU THINK IS THE FAULT? THE MACHINE IS QUITE NEW.
IN MY OPINION I THINK THE PROBLEM LIES AT THE CIRCUIT BOARD, PERHAPS THE SPEEDCONTROLLER. DOES THE ELECTRIC MOTOR WORKS WITH AC OR DC POWER AND AT WHAT VOLTAGE RANGE?
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Posted on Jul 05, 2008
  • 45 Answers
SOURCE: Speed Control Unit test?
Take off the back cover. there should be 2 screws on top of a piece of metal, 1 on bottom. Start on turn. it should go about 1x a second. Turn the top scrws. Then go to 6. it should be 3x a second. Use the bottom screw to adjust that. When turn and 6 are corrrect, all other sppeeds are right. There might be something else in between the back cover and the 3 screw panel.
Posted on Aug 19, 2008
  • 16 Answers
SOURCE: mixer starts running on selected speed then speeds up & quits
I'm not sure what model of Kitchenaid you have.  I have a professional 6 Quart model, KP26M1XPT. I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was actually defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what? My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.  This is critical!
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes less than 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Mar 21, 2009
SOURCE: MUM 6622 Motor Has voltage to it but will not run!
I have the same problem after running for a while, turning off then back on. It will not start. I found the heat sink fuse in the motor was burning out. When the motor gets hot then turned off, no fan and the heat build up enough to melt the heat fuse. It would be an easy replacement if I could find where to get them. To find it on the motor, look at the wire going from one corner of the motor to another, but looks like it goes into the motor in between. Pull on that going into the motor to lift the heat fuse out.
Posted on Apr 11, 2009
vinceisaac
  • 2432 Answers
SOURCE: Cuisinart hand mixer model # HTM-7L - totally
hi this is how are you going to isolate if where is the problem since totally dead set and no sign of obvious defective part. you need test voltage with the use of digital tester from ac line going to the ac to dc converter board check if their is a output dc voltage which supply dc voltage to the motor their might be a defective rectifier diode or regulator.you will notice if their is led speed display that means their is a supply. now another recommendation to check if your motor is good if you have a 12v adapter supply you can supply the motor just to know if it is good. hope it will help you to trouble shoot the unit good luck thanks.
Posted on Jul 04, 2011
Hello - I need the service manual (preferably with exploded diagram) of the Kenwood Chef KM201. Can anyone help me?
Have you tried here? http://www.u-manual.com/download-manual-now-for-free-10/267574/mixer-kenwood-km-201-chef.html
Dec 06, 2014 | Kenwood Chef Major A701 A901 Cm170 Km201...
Kenwood prospero wont start
There are interlock switches on that unit so that it wont come on with out the attachments. One of them is bad or loose
Dec 02, 2013 | Kenwood Prospero Compact Km265 4.3 Litre...
Kenwood KM201 Service Manual
I need service manual for Kenwood KM 201 , can you help me
many thanks
g.raiwisque@reflex-canon.fr
Nov 26, 2011 | Food Mixers
It is not working completely. all fuses and door switches are well pls help
check the power cord possible damage and the motor resistance if ok. also the pcb board
Mar 06, 2011 | Kenwood KM800 Major Classic Stand Mixer
How many amper has a kenwood km 800. Rosmarie
at 800 watts and your voltage is 120vac it is 800/120 = 6.66 amps
Jun 27, 2009 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood Chef (model no.KM 300)
Hi, check in ebay.co.uk if the seller have worldwide delivery.
or check in kenwoodworld.com
remember for model km only fit A993 and A337
best Regards
May 28, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood Major Mixer
Thank you for your time. I contacted the Kenwood company in England.
Apr 05, 2008 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
59 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
