Question about Dryers
How do you reset high limit stat on a zanussi zde26100w tumble dryer
2 Suggested Answers
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
My White knight vented tumble dryer is dead yet I had just dried a of clothes earlier change fuse in plug nothing still working
if the dryer hasn't been cleaned out and the vent line and this should be done at least once a year you could have taken out the thermal fuse or the high limit t-stat,if it has a belt switch then the belt could have snapped,only way is to take it apart and get in there with a meter,if it's clogged with lint and can't move air it can overheat and take out one of the t-stats as a safety so you don't have a fire
Nov 18, 2017 | Dryers
My tumble dryer ois not heating ?
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
this could be the stats or the drum is not turning Common faults -
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Our tumble dryer has no heat
check your cercite braker first and reset it,next make sure you have 240 volt's going to dryer.next un plug dryer.locate dryer element and use a continueaty meater to check element.also check high limit thermal switch,also check for bad wireing.most dryer's have two high limit switch's.if every thing check's out, than you nead to get a service call.
Nov 15, 2009 | Dryers
Zanussi tumbledrier TC7103W not heating
Common faults -
Aug 30, 2009 | Zanussi TC7114W Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
Top Dryers Experts
