Question about Coffee Makers & Espresso Machines
Cuisinart DCC2000-won't turn on
I run about 5 cups of white vinegar thru this am but hardly any came out--now it will not turn on. I have checked with other plugs but still won't turn on
Hi wd,
My recent experience(s) is the clock/timer is malfunctioning and there's really nothing servicable, i.e.: nothing thet you can solve locally. If you're still within the Warranty period, your only recourse is to call the Cuisinart folks for a Return Authorization (RA) and have them ship you a new unit.
However not to be the bearer of doom, the Replacement Unit's Warranty will only cover the remainder of the Initial Unit. And the Replacement Unit may begin to show the same symptoms after 6 to 12 months.
Not to be misunderstood, As a "dyed-in-the-wool coffee person", I loved and depended on my DCC2000(s), both of them. My third replacement is a Bunn commercial unit (at about 3x the price, no bells, no whistles, no timers, etc.. that consistently delivers 10 cups in 3-4 minutes...
Nuff Sed
DaveD
Posted on Aug 29, 2010
My Cuisinart coffeemaker is clogged. How do I find the water line to unglog?
Fill it with white vinegar, let sit overnight. Turn it on in the morning and Jerry it run with the vinegar in it. Should dissolve the deposits that form in the heating elements.
Jun 29, 2014 | Cuisinart Dcc-1100 12-cup Programmable...
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
How do I clean my coffee maker? I have very hard water.
i have a Cuisinart also and this is what i do: fill the resevoir with white vinegar and start the machine. once it has started through, shut if off for about 2 hours, then start it again. do this a couple of times using the same vinegar. afterwards run about 3 pots of cold water through to rinse it out, this should help clear the pumping tubes inside.
Nov 12, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Does not complete the brewing cycle. Only cycles 1/3 of the water. 1-4 cup is NOT turned on.
First remove charcoal filter. Your coffee maker is clogged with hard water grime. Run 5 cups of vinegar through it twice, then follow with a couple of rounds of water to get the vinegar taste out. It will be as good as new.
Oct 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
What is the best way to clean my cuisinart coffee maker?
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
101 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
