Question about Compaq Armada E500 Notebook
Compaq Armada E500 PC Notebook Display Completly Out
I had my notebook connected to a docking station with an external moniter,a wireless mouse and keyboard, and wirelesw network card attached. After a pretty bad thunderstorm which knocked out the power my notebook would boot up(I could hear the windows start-up sounds) but I had no display. I checked the ext4ernal moniter and it was not working. I attached my notebook to a working external moniter and it had the display but I still don't have a display on my laptop. What should I try to fix this?
  • 12 Answers
Hi Jeryl; Im sorry to have to te3ll you but when the power went out it sent a surge to the external monitor . This blew the monitor which in turn blew your video display. This is a not so uncommon problem with laptop displays. They are very fragile. Especially when it comes to power urges. The only way you can fix this is to replace the monitor. Even this may not fix the problem. It could be any one of a few thousand parts inside your laptop. Best advice would be to let your local repair shop do the repair. Hope this has helped. If it has please accept this answer. Thank you; HELP2DIY
Posted on Jul 01, 2007
SOURCE:
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
Where is the wireless button on the E500
I have E500 and it dont have actual button, Insert wireless card open network, click on wireless let connect and away you go surfing the net.Also make sure in internet opitions that wireless is enabled. Hope this helps
Feb 21, 2011 | Compaq Armada E500 Notebook
How can i connect a wireless internet connection with a compaq armada E500
Get a PCMCIA to USB2 adapter that has an external 5 Volt connection to it to supply the higher current for the wireless adapter. The power can come from the USB via USB adapter cable
After installing the adapter, the USB wireless device should be installed just like in any later notebook. The wireless device requires USB2 and high power. and won't work off a powered hub.
Feb 05, 2010 | Compaq Armada E500 Notebook
Compaq Armada E500 is working, but display is so dark, I need a flashlight to see the display to navigate. ideas please?
Backlight or the inventer is gone, check www.pchub.com for parts. I got one of these laptops for around 20usd, it may not be worth the repair. You can also use a external display, the laptop has a VGA - for a desktop display connector and a tv connector aswell.
VGA- blue connector 3 lines of pins on the back.
TV connector, yellow, round connector on the right side.
Aug 23, 2009 | Compaq Armada E500 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Mouse
I had the same problem with my compaq armada e500. I've been using an external PS/2 mouse for over a year and just now fixed the built-in touchpad buttons. In the mouse settings applet in control panel there is a setting for click speed. In Win 2k there is a little jack-in-the-box test icon. I moved the click speed slider to the slowest setting and my mouse came back like magic. I've searched and found lots of people with this issue, I can't say this is the only solution, but it certainly was easy. Of course, first I downloaded all the original COMPAQ Armada e500 notebookPC touchpad software from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodTypeId=321957&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=181
BTW, I appreciate the workarounds offered by posters here and on other tech support sites, but when someone wants to fix something, it doesn't help to say, "Oh, just give it up and spend money to get around the problem."
If you are still out there, dave, Instead of a USB hub, may I suggest (if you have the resources) picking up a PCMCIA card with at least two more USB ports? They are less than $100 and it really saved my neck when my onboard USB died. Don't be offended, but just in case you haven't noticed you have them, the slots are on the right side of your E500, just to the left of the headset and mic ports. The e500 has two slots and the cards come in different sizes for different laptops, but ours is (luckily) pretty standard. I bought my card at BestBuy.
Feb 12, 2008 | Compaq Armada E500 Notebook
NO DISPLAY FAN NOT WORKING
Try external monitor!If it work the problem is VGA!
Dec 07, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
