Question about Biostar M7NCD ULTRA Motherboard
Windows did not detect SATA during installation
Hi! i have a biostar m7ncd ultra mobo, amd athlon 1800+ processor, 1.2g memory, and 80g0g seagate sata drive. i tried to intall windows on the sata drive but i got a message sying that windows did not detect any drives present on the computer. the sata drive i not new. it worked well when used as a back up drive on my other computer. it has since been reformatte and partitined using norton partition magic. the computer i am installing it on now, used to have a 40g ide drive and the sata drive could be read then. actually at boot-up, the sata can be seen on the post screen. it is only when i try to install windows that the drive could not be detected. i will appreciate any input on this subject. thank you.
  • 432 Answers
You need the manual to your motherboard to set it up in the BIOS. http://www.biostar-usa.com/docsmain.asp In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Posted on Jun 30, 2007
I could not found biostar N68S3B driver for windows 7 ultimate 32-bit os
Hi
I went to the download drivers page of the BioStar website for your mobo here:
N68S3B
and the VGA driver for Vista and Windows 7 is the same one 8.15.11.8634 (the "x86" indicates 32-bit, but the driver looks to be the same for both 32 & 64 bit).
Your question about the AMD Athlon can be answered quite easily. It is a CPU and does not need any specific driver. You should however download and install the chipset drivers for the mobo.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 24, 2014 | Biostar Computers & Internet
Unknown processor for NF61S MICRO AM2 SE VER 6.0
additional question, can
BIOSTAR NF61S Micro AM2
a
AMD dual core X2 7750 2.7processor? which is a am2+ socket processor.
Sep 15, 2012 | Biostar NF61S MICRO AM2 SE...
I ned sm bus controlers
Your windows install cd is not going to have it, you have to get it from your motherboard supplyer.
Who makes your motherboard and what is the model number? ASUS? Intel? Biostar?
Aug 27, 2011 | AMD Athlon XP , 1800 Mhz (axmd1800fqq3)
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
How fast of an amd athlon processor can i use in a biostar m7mkb?
According to these specs 500 Mhz and up
http://www.motherboard.cz/mb/biostar/M7MKB.htm
Your motherboard supports a slot A Athlon.
The fastest looks like up to 1Ghz as according to CPU World:
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20(Slot%20A).html
Hope this info answers your questions. Feel free to comment if you need further info from me.
Rate me please when you get the chance.
Mar 04, 2009 | Biostar Slot A M7MKB Motherboard
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Jan 15, 2008 | Biostar M7NCD ULTRA Motherboard
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
SATA problem during windows install
try other memory or if you have 2 dimms take one out and try same to both dimms
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Biostar M7NCD ULTRA Motherboard Logo
151 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
