Question about Porter Cable Cable No. FC350A Clipped Head Framer
Air nailer won't nail
I'm using a Porter Cable finish nailer and about half the time it misfires. Sounds the same, dimples the wood, but no nail comes out. It's several years old and I've never done any sort of maintenance to it. I've got plenty of air pressure--at least 100 pounds.
  • 2,176 Answers
If youve never done anything to it could be a couple things. Have you kept it oiled (about 6-8 drops) before using and again at lunch if construction type work. Check the nails to make sure they move freely in the magazine Check the nail guage for proper size. and what I would do is fire it till it skips disconnect the air from tool and open the front door (for removing jams) and see the driver position. If it is partially down that would be the problem, check the driver for being bent. Lastly remove all nails and just tap the nose on a piece of wood and again check the driver position, if it moves or falls freely then the tool would have to have new rubber which might be a good idea anyway. Get back to me with the model number and I will research and see if they make an o ring kit.
Posted on Jan 21, 2009
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
My Porter Cable finish nailer keeps discharging 2 nails on 1 shot!
I have the same brad nailer and the samething happened to me, only after looking at a few nails from the previous package i had and the new package i had bought ,i notice i had bougth the wrong gauge size nail, if the nails are a size smaller the driver will grab 2 nails when it comes down .this could be your problem too. check the gauge size of your nails make sure their the right ones for your nailer.
Apr 03, 2011 | Porter Cable Tools & Hardware - Others
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Gun keeps jaming with 16 ga. porter cable nails why?
make sure that the slide is putting pressure on the nail oil the slide
Dec 09, 2010 | Porter Cable Cable Factory Reconditioned...
250B finish nailer has begun to shoot 2 nails at a time
try to regrind the driver blade, there should be a small nick on the driver blade where the nails are fed in, if the driver is to fat it will catch 2 nails,and cause nail jambs.
May 03, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
I have a PC nailer (Finish) It is misfiring? was working fine. Now it does not NAIL although I can see the indentation on the wood ...help!!!!
Check the magazine area near the head for a jammed nail or other feed obstruction. It sounds like the driver is hitting the wood ok. Did you change nails (brand, type, or size) when this occurred? Make sure the magazine feed spring is ok.
Nov 12, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Porter Cable Cable No. FC350A Clipped Head Framer Logo
397 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
