Question about Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750c not detecting paper on ADF
States "No paper on ADF paper chute or hopper error code DS32003"
zone48
  • 25 Answers
SOURCE: fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Posted on Jan 20, 2009
  • 12 Answers
SOURCE: fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Posted on Aug 20, 2009
  • 5167 Answers
SOURCE: Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Posted on Apr 30, 2010
TechSatya
  • 104 Answers
SOURCE: Anomaly in the light intensity of ADF front side. Fujitsu 5750c s
This error code denotes ADF front side scanning optical alarm (lower optical unit ADF) which indicates ADF (front) lamp intensity check. Please follow the steps provided below:
1. Is the upper glass (white sheet guide)of the reading section dirty?
Open the ADF, and clean the sheet guide (white part) and the glass.
# When operating the scanner, the ADF’s inside glass becomes very hot. Take serious caution as the heat can cause burns. Before you clean the inside of the scanner, turn off its power and unplug the AC adapter from the outlet and wait (at least three minutes) until it gets cold.Be careful not to pinch your fingers when the ADF cover is being closed.
Note: Cleaning should be done approximately every 10,000 sheets scanned, though it may vary depending on types of
documents scanned. More frequent cleaning is necessary when the following types of documents are scanned:
- Smooth surface document such as coated paper
- Documents printed on almost entire surface
- Documents processed with chemical materials such as carbonless paper
- Paper with a high calcium content
- Pages with pencil lead
- Document where toner is not fused sufficiently.
If the above does not help, then the issue is caused by any of the followings for which you may have to contact the Fujitsu Expert/Engineer.
1. Lower Optical unit ADF may be dirty. (Remove any dirt inside of the mirrors and lens of the Optical unit ADF with blow brush. Do not use air sprays which may build up condensation on the mirrors.)
2. Lower lamp may not be functioning properly.
3. The connecting cables might be damaged.
4. The connectors are not connected properly.
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Posted on Jul 19, 2010
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Regards,
TechSatya
Jun 28, 2010 | Fujitsu fi-5750C Flatbed Scanner
ADF rotate
Remove the 2 thumbscrews fixing the ADF in place. These are found on the underside of the flatbed cover. Look at your "Getting Started" guide book for a picture. Slide the ADF to the middle of the scanner, then rotate it counter-clockwise.
Feb 16, 2009 | Fujitsu fi-5750C Flatbed Scanner
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fi 5750c adf will not initialise
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750C Flatbed Scanner Logo
1,178 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
