Question about IBM (08K3261) for ThinkPad A20P, A20M, A21P, A22P Graphic Card
Windows 2000 Pro Recovery Disk
I burned a copy of the Windows 2000 Recovery, but I still don't know how to get to a prompt to run the program on my computer since it won't boot up.  Please Help!!
    President:
  • 2,692 Answers
Go into the BIOS setup screen and have it load from the cd first. The run cd . Keep pressing enter until it takes.
Posted on Jan 24, 2009
How to recover Acer Windows password?
Recover windows password, why don't remove the password with Windows Password Recovery Tool 3.0.
If you can not remember the windows admin password, try to reset it with a reset disk. Free download windows password Recovery from http://www.windowspasswordsrecovery.com and there is a .iso file included. Burn the .ISO file onto a blank CD which is so-called windows password Recovery disk. With this disk, you can reset windows password without erasing anything
Jun 07, 2012 | Acer Universal 90w Ac Brand-new Adapter...
Biostar m7ncd pro freezes up
Run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 29, 2012 | Computers & Internet
Completly free copy of windows 7 boot disc
If it tries to boot up, Borrow a Repair disk or Operating System Disc from a neighbor, friend, relative or co-worker.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 22, 2012 | Acer Aspire AS5734Z4836 T4500 Notebook
2000-0146 error code how i fix it
Try the Check Disk Utility.
Apr 25, 2012 | Dell Computers & Internet
Will not start, windows says it starting but never do . don't have recovery disk
Run the Check Disk Utility with your Vista Ultimate disk.
Apr 21, 2012 | Gateway LX6810-01 PC Desktop
CD DRIVERS MISSING DON'T HAVE A RECOVERY DISK
Run the Check Disk Utility with your Vista Ultimate Disk
Apr 21, 2012 | Gateway LX6810 PC Desktop
I need a recovery disk for gateway nx860s, do you know where i can find a free download?
The recovery software for the Gateway NX860s is stored on the hard drive itself. As long as you have the original hard disk drive and have not repartition the drive the information is probably still there.
You can create recovery CD's by doing the following.
  • Click Start->Run
  • Type the following, including the quotation marks on the run line: "C:\WINDOWS\CREATOR\CD Creator.exe" /drv
  • Click 'Burn ISO'
  • click 'Start Creation'
  • Select either CD or DVD depending on which type of media you are writing to and click 'OK'
  • The application will copy the files to your disk, when it's complete click 'OK'
If you are not able to run the recovery application but believe that the recovery files are still on the hard disk drive then you will need to run a recovery on the system being rebooting and pressing F11 when prompted to start a system recovery. The actual recovery will restore you access to the files to later create a back up cdrom.
Dec 22, 2009 | Gateway NX860X Notebook
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
WIN PRO 2000 RECOVERY DISK
BEFORE YOU DOWNLOAD THE PROGRAM ONTO THE CD-ROM DID YOU FORMAT IT TO MAKE IT BOOTABLE, IF NOT THAN IT WILL NOT WORK, YOU COPIED THE PROGRAM, THE COMPUTER SEES THE PROGRAM, BUT IT CANNOT DO ANYTHING UNLESS THE COMMAND ARE THERE TO TELL IT WHAT TO DO.
YOU CAN TRY ACCESSING THE PROGRAM FROM THE CD-ROM, WHILE YOU ARE IN THE PROGRAM FROM THE CD YOU CAN TRY AND TYPE SETUP, RUN,
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
WINNR\SYSTEM32\CONFIG\SYSTEM error
do it
1.
Use the Windows 2000 CD-ROM or the Windows 2000 Startup disk to start the computer. 2. When you see the "Welcome to Setup" message, press R for "repair." 3. Press C to run the Recovery Console tool. 4. Select the installation that you want to repair. 5. Type the administrator password.
If the computer is a domain controller, type the password for Directory Services Restore Mode when you are prompted to do so.For additional information about the Recovery Console tool, click the article numbers below to view the articles in the Microsoft Knowledge Base: 239803 (http://support.microsoft.com/kb/239803/EN-US/) How to Change the Recovery Console Administrator Password on a Domain Controller 223301 (http://support.microsoft.com/kb/223301/EN-US/) Protection of the Administrator Account in the Offline SAM 6. At the Recovery Console command prompt, type the following commands, pressing ENTER after you type each command: cd system32\config
ren system system.old
ren system.alt systemalt.old
7. If you have run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools, copy the backup of the System hive from the %SystemRoot%\Repair\Regback folder.
If you have not run the Emergency Repair Disk Wizard, copy the default System hive from the %SystemRoot%\Repair folder.
IMPORTANT: You need to restore the most recent copy of the System hive. You also need to reinstall any hardware device drivers or programs that run as services that you installed since the last time that you updated your Emergency Repair Disk.
To copy the default System hive, type the following command, and then press ENTER: copy c:\winnt\repair\system c:\winnt\system32\config To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command, and then press ENTER: copy c:\winnt\repair\regback\system c:\winnt\system32\config 8. At the command prompt, type exit, and then press ENTER to restart your computer.
Jun 23, 2008 | Compaq Presario 1200 Notebook
Computers & Internet Logo
78 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
