Question about Air Tools & Compressors
Hose End Trigger Gun Gardena Premium Metal Spray G8107 leaking
Leaks continuously from the trigger
  • Gary Nason Jan 08, 2013
    the gardena G8107 is a garden hose spray and I cannot dismantle it. can someone show me how?
  • 1383 Answers
SOURCE: Trigger problems
I have repaird hundreds of nail guns with a problem similar to yours. Depending on the brand and model, the problem can be repaired by checking the following. Headvalve orings should be checked for wear and any surface that the orings contact must be smooth and free from scratches. If the surfaces are scratched try to smooth with fine sandpaper and use light grease instead of oil when assembling. The safety contact foot may not be reaching high enough into the trigger to properly push in the trigger button. Check for worn spots on the trigger that may be filled in with epoxy, loose fitting trigger caused by worn roll pin or retaining pin. Some of the trigger valves as used on many bostitch nailers (tva6 valve) used a plastic pin which contacts the trigger. If this pin is loose or worn the valve should be replaced. Some tva6 valves have a vinyl looking sort of oring that fits too loose on the spool. This vinyl oring in not available by itself but if the oring fits too loose the gun will not fire and leak air. On bostitch remove the trigger and the rollpins holding the trigger valve and apply air to gun to eject valve. (use heavy glove to catch valve as it will come out with force)
Posted on Nov 25, 2008
rowdy45176
  • 2176 Answers
SOURCE: Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Posted on Feb 06, 2009
  • 1383 Answers
SOURCE: air leak on framing gun
You can repair this gun. Parts and breakdown are at www.bostitch.com look for service /parts and enter your model number. There you will the parts available for purchase. You will need the tva11 trigger valve. Easy to install. Remove roll pins that hold trigger and trigger valve. Remove the trigger to expose the tva11 valve. With the roll pin/s removed that hold the trigger valve you will be connecting air supply. Use heavy glove to catch valve as you apply air pressure. You may reduce pressure to airline to reduce pop-out force. Before you install the new valve check port for sharp edges and debris. Good luck with your repair.
Posted on Mar 16, 2009
rick_amick
  • 69 Answers
SOURCE: not spraying
Sounds like you need to completly dissasemble and clean thorougly.
Posted on Mar 23, 2009
  • 1383 Answers
SOURCE: Stanley Framing Nailer Leaking Air Around Trigger
Your tva11 valve can be repaired easily if you have a source for orings. I purchase orings from several companies including lowes (in plumbing dept sold in 10 pack for about dollar), www.grainger.com (oring kit metric, cost about $10) harbor freight (oring kit about $5), also orings are sold by size at bearing companies. I have repaired many of these valves by just cleaning debris and lubing with silicone paste (sold at lowes in plumbing dept used for lubing faucet orings). To attempt repair of valve, remove nails, remove roll pin that holds trigger (3mm) to expose tva11 valve. Mark position of valve in body of gun because the retaining pins fit thru an indention in the valve. Next remove roll pin/s that hold tva11 valve, they are just above the valve in the body of the gun(3mm x 30mm). You will need to apply air pressure to gun to remove the valve, however use heavy glove to catch valve because it can come out with force. (try lowering air pressure to gun for this procedure. With valve in hand, use marker to mark position of inner part in relation to outer, remove the two pins that hold valve together. Push out the inner cylinder and look at the middle oring(usually the problem, could be loose or cut) , If cut or loose replace and lube with silicone paste and re-assemble. Check outer orings for nicks, replace as necessary (usually good). Clean valve port, lube port, then re-install valve into gun and insert temporary retaining pin and test for leak. You should be good to go. Good luck and email if you have questions.
Posted on Mar 30, 2009
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
My husky framing nailer leaks air around trigger
Leak around trigger could be trigger valve internal orings or orings on the outside of the trigger valve making contact against the body of the gun. Spray soapy water to determine where the air is leaking from. If air is leaking around the outside of the valve, most likely the orings were cut upon installation of the valve. If leaking from internal valve, most likely worn or broken oring; easy to fix if you have a source for orings.
To remove the trigger valve for service or inspection (take close-up photo of trigger area for reference ):
disconnect airline, remove nails, remove trigger retainer pin, remove trigger, remove roll pin /s holding trigger valve in place (use 3mm punch to remove retainer roll pins which are located in the body of the gun just above the trigger valve). With retainer pin/s removed and with gloved hand (under trigger valve), apply air pressure to gun to blow out the trigger valve (use lower pressure to push out trigger valve because it could come out with force.). With trigger valve in hand notice that there are two slots or groove cut neer top of the valve where the retainer pins rest, you will need to reinstall valve into body with slots aligned to retainer pins. Remove retainer pins holding trigger together to pull out internal valve. Good luck and post again if your have other question about the trigger valve.
Nov 15, 2012 | Air Tools & Compressors
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 | Garden
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
NRA833AA model. air is leaking out of trigger valve & will not fire. require manual to check operation.
Here is a link to hitachi web site listing for your gun. Look at the bottom of the page for pdf files of parts lists and manual.
http://www.hitachipowertools.com/store_item.php?iID=154&arrPath=1,9,43,p154,
There are two areas around trigger that can leak air. Spray soapy water on trigger stem and/or plunger valve. If leak is at trigger stem check vinyl ball. If leak is at plunger valve, most likely worn or broken oring inside of gun. Remove head and pull outer ring to reveal two orings. A worn outer oring will cause leak at plunger. If orings are ok on outer ring, pull cylinder and check for scratches where orings contact. If scratched, sand with 400 grit paper untill smooth and repack gun with oring kit. Good luck.
Jan 09, 2011 | Hitachi NR83AA3 3 1/4" Clipped Head...
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Iwata w400 air leak behind trigger problem
Have you traced the exact spot of the leak?
I will assume you have not. the reason it's important is because if there is a crack in the o-ring seat there is nothing you can do. So trace the leak. Try a small amount of auto air conditioner leak detector or something similar even ink from an ink pen will work. Place it in the air inlet, hook up your air line and trigger your gun for a 10 to 15 seconds. disassemble your trigger and see if you can locate the offending spot. Though this method has worked for me in the past, it's not something I would normally recommend. However the gun you have is to expensive to just write off.
The alternative is to contact Iwata and seek help.
Good luck.
Jun 23, 2009 | RTO Iwata 1.4 W-400 Gravity Feed Spray...
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Air Tools & Compressors Logo
346 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
