Question about Brother Sewing Machines
How do l change a bulb on the brother vx1125 - Brother Sewing Machines
2 Suggested Answers
  • 255 Answers
SOURCE: My brother vx1125 won't draw
The most common reason why a machine won't pick up the bobbin thread is because the needle is inserted wrong. Check to make sure that the flat side of the needle shank is facing away from you. Another thing you might check is that the needle isn't bent.
Hope this helps!
Robbie
Posted on Aug 10, 2010
I have had to replace light bulb three times in 3 days
Try to find an LED version of the bulb to replace this one. It'll run cooler, take less energy and will last a lot longer
Oct 14, 2014 | Brother Sewing Machines
How do you change the light bulb on the Disney 270D embroidery machinr
The Brother 270D uses an LED light. Part number XC3503021. The assembly costs about $25. I do not believe this is a user installable part.
Apr 01, 2014 | Brother SE-270D Computerized Sewing...
How to open casing to change the bulb
on the left hand side of the machine, look for a plastic tab, gently pry it off & it should reveal a hidden screw, undue the screw being careful not to strip the thread & the face plate should come off so you can gain access to the bulb, after you change the bulb just reverse all the instructions to put everything back togeather
Mar 15, 2012 | Brother XL-2600
How to change the light bulb of my brother xl2600i
on the left of the machine you should see a plastic plug, gently pry it loose with a small screw driver & it should show a hidden screw, undo the screw & the plastic cover should come off, to replace the bulb, the replace the cover & screw & plastic plug
Feb 25, 2012 | Brother Sewing Machines
How do you change the light bulb?
on the brother website they have a free operation manual that shows how to change the light bulb
on the home page to the left look for manuals under support
click on it & then under select product group choose home sewing & embroidery
& select model LS2125
at the back behind the face plate on the top left there is a screw take it out & turn the machine back around to face you & the face plate will come off & the bulb is accessable
Dec 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
How to open the right front cover on a brother Ls2125? The manual only talks about how to change the light bulb.
I look at my manual & at the back of the of the thread take up lever ,where the thread guide is behind the machine on the top left hand side is a screw, just unscrew it take off the face plate & change the bulb & put the screw back in
Dec 10, 2010 | Brother LS-2125 Mechanical Sewing Machine
How do I open the machine to change the light bulb. model ls-1217
Hi
Do you have a manual?
You can download a free manual from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Click on the maintenance section of the manual. The first part of this section shows how to change the light bulb.
Hope this helps!
Nov 12, 2010 | Brother XL-3510 Mechanical Sewing Machine
How to change bulb
On page 42 of your manual, it gives you the instructions to do it. If, you do not have a manual, download one for free at www.brother-usa.com . If, this helped, please give testimonial. Good luck
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
My brother vx1125 won't draw up the lower tread
Hope this helps!
Robbie
Aug 10, 2010 | Sewing Machines
Sewing Machines Logo
42 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
