Question about Locks & Locksmithing
Toyota granvia master drivers door lock faulty
Key won,t unlock doors
SOURCE: i need to take my master lock 5400 off the door, is their a switch
ONCE YOU HAVE OPENED IT YOU WILL NOTICE A SMALL CHROMED PIN INTHE TOP RIGHT HAND CORNER. MOVE THIS TO THE LEFT WHILE PULLING THE BODY DOWN AND THE SHACKLE WILL OPEN
Posted on Dec 07, 2007
  • 25 Answers
SOURCE: lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Posted on Apr 24, 2008
  • 12 Answers
SOURCE: drivers side door lock
is the lock mechanism siezed,or is the linkage disconected?
Posted on Jun 15, 2008
  • 38 Answers
SOURCE: kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Posted on Sep 11, 2008
bad_dog1
  • 104 Answers
SOURCE: drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
Posted on Mar 09, 2009
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Sep 18, 2013 | 2001 Toyota Land Cruiser
2002 rav4 doors won't unlock only lock
Change the battery in the remote key.
Sep 25, 2017 | 2002 Toyota RAV4
Coding spare key for a Toyota Echo?
Adding key.
Note:
You must be having one working master key to perform this function.
1. Start with the key out of the ignition, drivers door is open all others closed and drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock and then unlock once indicating successful programming. If the door locks cycle twice, repeat steps A and B in step 6 as the remote was not accepted.
7. Open drivers door.
Jan 09, 2013 | 2001 Toyota Echo
Doors won't lock, thinks key in ignition
Troubleshooting is required to inspect few parts.It can be issue with ignition switch.Its not getting off.Or issue with sensor or wiring.Or its faulty lock itself.Click the link below and follow the troubleshooting:----Driver Door will not lock or unlock with Key or Remote? http://whatisbyme.blogspot.in/2012/05/1998-toyota-landcruiser-driver-door.html
Driver side door will not lock or unlock with Remote? http://technoanswers.blogspot.in/2012/04/2009-toyota-tundra-driver-side-door.html
Central locking not working ? http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
Jul 17, 2012 | 2002 Subaru Outback
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
2005 camry xle. remote control will unlock drivers door but not the others. it will lock all doors. inside driver door control will unlock diver door only but will lock all doors. . system worked ok...
Hi Wmannschneid,
I have come across this problem earlier as well,
It seems that the remote has been programmed to ONLY unlock the driver door and not the other doors with one push , to solve this problem you need to follow the below instructions :-
Hold down the lock and the unlock key on the remote TOGETHER for at least 10 seconds and then you will have the setting which will reopen all the doors with one push.
Hope this helps ..:)
Jun 28, 2011 | GPS
Key buttons will not operate locking system,i have changed battery but still no good.use master key,gets me into the car but alarm goes off and also when i attempt to drive it.
I have the same problem kinda. Lost my master key and sent my ecu off with a home made 2 button key to program immobiliser. This key works to start the engin and drive but I cannot get the key to program with the alarm and locking system. You can try the following steps as may work for you.
I can get my car into programming mode after step 1 but step 2 does not work for me. The locks do not go off at all, not once or twice. Battery in remote key is fine as LCD lights red.
Can anyone help please?
Toyota celica 2000 - 2005 remote keyless entry programming guide
STEP 1
1. Key out of the ignition. Open the drivers door , all other doors are closed . Driver door is unlocked
a. Insert the key into the ignition ( do not turn it ) take key out
b. Insert the key into the ignition ( do not turn it ) take key out
a. Close and then open the drivers door.
b. Close and then open the drivers door.
c. Insert the key into the ignition ( do not turn it ) and pull it out.
c. Close drivers door.
d. Insert the key into the ignition and leave it in the ignition.
Turn the ignition to on (as far as you can go without turning the engine over ), then back to off .
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
STEP 2 (Does not work for me)
a. Press the lock and unlock buttons on the transmitter simultaneously for 2 seconds
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Hope this works for you.
Hayley
Oct 03, 2010 | 2000 Toyota Celica
1998 Toyota 4runner driver side power door lock problem.
probably gonna have to take the door panel off. You say it wont unlock or lock with the key? if thats the case its probably broke inside the door.
Aug 20, 2009 | 2000 Toyota 4Runner
Locks & Locksmithing Logo
29 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
