Question about Nikon N90S 35mm SLR Camera
Nikon N90s won't turn on
Worked fine with SB-26 flash. Now stopped working suddenly with new batteries.
    Top Expert:
  • Nikon Master
  • 14,162 Answers
Posted on Jul 18, 2016
4 Suggested Answers
  • 383 Answers
SOURCE: what does A ERR mean?
There are several situations when this message happens and the camera locks up, and almost none of them has anything to do with the cause stated in the camera manual: film DX coding error. (If it is truly a DX-coding error, manually setting the ISO speed of the film should solve the problem. This could happen in cold weather.) Scenario One: when using Alkaline batteries and the batteries are almost exhausted, and yet one continues to shoot. The battery may not have enough power to complete the shutter firing operation (which usually includes: mirror up, close down diaphragm, shutter fire, mirror down, open diaphragm, advance film, and charge the shutter for next frame). The camera could be lock up in the middle of the operation, left with a dimmed viewfinder. Usually an indication appears quite early if one pays attention: when the batteries are almost exhausted, the film advance becomes noticeably slow. In normal situation film advance is very fast and one cannot distinguish it from other noise such as mirror flipping. When the batteries almost exhausted, the film-advance could take almost 1 second, and the noise of film advancing has been mistakenly identified by some as "beep". I think those is the result of over-adjustment for the Premature Battery Indication problem. This scenario is particular to using alkaline batteries, due to the peculiar behavior of the alkaline battery: even when its power is almost exhausted, it still has a pretty high voltage. Solution: replace the batteries and fire the shutter once should solve the problem. I am pretty sure this is normal, since it happened to me several times, and I once deliberately repeated this happening. Scenario Two: At the end of a roll, when the remaining film is too short for one more frame but long enough to fool the camera, the camera could end up with "Err" message. Solution: rewind the film and load with the new one, and possibly fire the shutter once could solve the problem. (This has never happened to me, but summarized from other’s reports.) Scenario Three: I've heard of two reports: happened in the middle of a roll, with sufficient battery power. I have no idea what’s going on. (Could be really a DX-coding problem, which does not necessarily occur just at the beginning of a roll.) Solution: probably should send the camera in for a check. (Also, both reports of this problem occurs while using Kodachrome films.)
Posted on Oct 15, 2008
  • 685 Answers
SOURCE: I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
Posted on Nov 24, 2009
Obertelli
  • 3006 Answers
SOURCE: Nikon Fe meter - warm batteries
If the batteries discharged sufficiently to become very warm in just a few seconds then there's an internal short circuit and the internal circuitry has almost certainly been fried beyond repair. To get warm so fast, those batteries will have shoved some significant current through circuitry designed to handle mere milliamps.
Your camera will be repairable using donor spares, but the repair will cost more than buying another fully functional FE especially when you add on the costs of the CLA (Clean, Lubricate, Adjust) service that it will almost certainly need and the likely need for foam light seal replacement. If you buy another FE it will also most likely need a CLA and seal replacement unless there's proof of it being recently done, but at least you won't have the additional costs of buying a donor FE, stripping it for parts and then doing a heart transplant on it.
On balance, yours is best used as a spares donor; you'll get some of what you spent back if you sell it as a spares/repairs example.
Sorry there's no fix, but I hope that you have still found my reply to be of some use. If so, please rate my answer.
Posted on Feb 22, 2010
Nikon sb400 ready light never comes on nikon d7000
Tried out my sb400 with my d7000, no problem, even with fairly used batteries. Try new batteries again, see how you go. If you use lithium batteries, make sure they are good ones, as lithium batteries die suddenly when used up,and can make you believe there's a problem with your flash. If this doesn't work you may have to send it to a Nikon Service Center
Feb 14, 2014 | Nikon SB-400 Flash
Changed batteries because some had corrision on them and now flash won't work at all?
Did you clean the contacts in the SB-600 when you discovered the corroded batteries? I use a pencil eraser followed by alcohol on a Q-tip. Make sure that all of the contacts are shinny and there is no remaining sulfate residue. If that does not solve the problem, there are other issues.
Aug 14, 2012 | Nikon Speedlight SB-600 TTL Flash
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
I have a Nikon N90S, and it stopped taking pictures after 15 shots. We stopped using the camera, and used our backup to finish the shoot. I thought that maybe the roll of film jammed, but when I...
Have you tried replacing the batteries? It sounds like the batteries may just be too low to wind film, but can function without a load.
I can't remember if the N90S has the vertical grip release or not, but if it does, have you attempted to use it, to see if the camera functions from that release, or on fully manual settings with a cable release? Are there any error messages reading out on the LCD top panel or in the viewfinder? Are you using an attached flash? What settings are you using?
If it's not functioning, on any settings including manual with film loaded, then it's most lilely in need of a visit to a repair shop to figure out where the issue lies.
But, I'd try new batteries first.
Jun 30, 2011 | Nikon N90S 35mm SLR Camera
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
I have a Nikon SB 800 that was working fine untill
Main circuit board broken, new one required, very expensive.
Aug 01, 2009 | Nikon Cameras
SB-29 speedlight overflash
Go Manual.
Set F Stop to higher number.
Can also lower the ISO.
atdlee@netzero.com
Jan 16, 2008 | Nikon Macro Speedlight SB-29 TTL Ring...
Nikon N90S 35mm SLR Camera Logo
131 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
