I have a JVC SP WA25 subwoofer in the back there is a black and red wire buttons then 2 seperate long wires coming out which are exposed and i want to connect it to my computer to my ASUS moniter ive
ITS AN OLD SUBWOOFER I THINK SO I DONT EVEN KNOW IF ITS EVEN POSSIBLE TO HOOK UP TO A COMPUTER,NOT LAPTOP
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
SOURCE: How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Posted on Oct 17, 2007
SOURCE: Wire for the Panasonic Subwoofer SB-WA340
my problem is l have only the sub-woofer and l want to know if l can use it without the dvd player and plz how will l connect it l will be very much happy it u give me the diagram for that u can email it to me at peebrown2@yahoo.com thank you
Posted on Sep 19, 2008
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
SOURCE: SP-PWM505 subwoofer does not stay on
Well i had exactly the same problem, my sub turned off right away when i turned the whole thing on. Well i opened the subwoofer and was trying to find out something unusual, i took out, i believe, internal amp, well, whatever that thing is, under the lid. Which one is screwed with 6 copper screws, so you unscrew those screws, lift that lid and that whole board comes out. On that board i find something like burn around one of the parts.
http://www.flickr.com/photos/28004328@N04/3333561417/in/photostream/
you can see it in the pick, the part q2902, then i contacted JVC. At the beginning they said i need to take the whole thing to service center and so on. But later i made them to tell me what kind of part that is, so here :http://www.jvcservice.com/store/ProductDetail.asp?Part=KTC3199/GL/-T
bought soldering gun in home depot for $15, returned after i was done. And that is it, just have to replace it, but total cost only $12 ($5 part +$7 shipping)
Posted on Mar 14, 2009
The wires from Line level converter where to hook them up?
Firstly, and definitely, your "black" is subwoofer line out.
Check your AV receiver if the subwoofer option is activated. I've known some receivers that have the option to disable subwoofers and push all the bass into their front speakers.
Next, you have to check if your subwoofer is on or off? what about the volume of the sub?
If your subwoofer is passive, which means it does not require powering up using the mains, then you will have to get a seperate amplifier to power the sub up.
Jun 05, 2012 | Cerwin Vega Audio Players & Recorders
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
How do you connect the back cables so the sound will come out right
There are four posts - two black and two red. They should be connected together, as shown in the picture. If you are missing the brass straps, simply use wire to reconnect the posts, black-black and red-red.
Then it's a simple matter of connecting the red (+) amplifier output to one of the red terminals, and the black (-) amplifier terminal to the black terminal on the KEF.
The KEF terminals can be seperated if you wish to "biamp" or "biwire" these speakers. Each black/red pair is dedicated to either the bass or the treble. For higher fidelity, some listeners prefer to run seperate wires from a single amplifier channel to each individual speaker input.clmrt5000_5.jpg
Jan 19, 2011 | KEF Audio Q75 Speaker
Maytag cook top Model # CSE 9000 ADB. A red, black, blue, yellow, white, and bare copper wire come out of the unit. How do I hook it up???
each colored wire is for a seperate burner, the white wire connects to the white neutral wire the bare wire connects to the ground the red and yellow wires connect to the red wire (L1) and the black and blue wires connect to the black wire (L2). i have the same model and i connected mine this way and it's working fine. mine is also connected in a box that has a seperate fuze for each burner so you can follow the red (L1) wires to the 2 fuzes and connect your red and yellow wires to these fuzes and the follow the black (L2) wire to it's 2 fuzes and connect your black and blue wires to these fuzes. i don't know if this box is necessary or ir you can just connect directly to the wiresin a regular box and rely on the breaker but it was already there from the old cooktop i replaced so i used it. hope this helps you
Jan 07, 2011 | Maytag 30 in. CSE9000 Electric Cooktop
I have 2 type r 12s and i forgot how the wires go when i took them out of the box. by wires i mean the two wires that connect from the sub to the round terminal in the back of the box. can someone show me...
If you want the speakers wired in parallel, then just make sure positive(red) to Positive(red), and negative(black) to Negative(black) .With 2 speakers, just jump from one speaker to the other....positive red to red, and negative black to black..
Apr 10, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
HAD TO REPLACE THE WIRE CONNECTORS BLACK AND RED AS THEY SHATTERED AND NOW I NEED TO KNOW WHAT WIRES GO WHERE.. THE INSIDE THE BOX WIRES
The red wire goes to the plus "+" teminal and the black goes to the negative "-" terminal. on the circuit board it should have the + and - marked.
Jan 16, 2010 | JVC SP-PW100 Subwoofer
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Feb 20, 2009 | JVC Audio Players & Recorders
I have a JVC KD-G441, which I have just put in the car. However, the preferred settings do not get saved if I turn off the engine. Does anyone know why? The car is a Peugeot 206 SW, if that helps. Jade
For all car cd players their is connector back side of the cd. having bunch of wires, in that if you connect squencily , the colour code of the wires are as follows
1. black for earth
2. red for acc, that you have to connect through ignition key +12volts
3. yellow, +B for continous supply that is battery
4. white and white with black stripp for front speskers
5. greay , greay black for front speaker
6. voilet ,voilet black for rear speaker
7. green, green black for rear speaker.
8 blue, for system remote .
if your yellow wire of +b is wrogly connected then memory problems comes
please try
regards
sam
Jul 12, 2008 | JVC Car Audio & Video
JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Apr 16, 2008 | JVC SP-PW100 Subwoofer
118 people viewed this question
 Grubhead
Grubhead
