Question about Panasonic Heating & Cooling
Panasonic airconditioner cs2473kr leaking water and I dont know how to access drip tray
I think this could be due to a blocked hose or cracked drip tray but I do not know how to access the unit
SolutionGuy
  • 331 Answers
SOURCE: kenmore refrigerator making spraying noise
Beth, sounds like your water reservoir in your fridge section has cracked. To get to it, remove the lower bins and shelves. You'll see it mounted on the back wall. After you see it, test by filling a cup of water from the dispenser on the freezer and watch the reservoir for the leak. To replace it, you'll need to contact your local appliance parts store and provide them with the complete model number (located on a sticker inside your fridge). It'll start with 3 digits then a decimal point then more digits (xxx.xxxxxxxx). Most reservoir replacement kits come with instructions and all the hardware you'll need. Hope this helps!
Posted on Sep 27, 2007
huuum
  • 750 Answers
SOURCE: DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
SOURCE: water dripping from unit
I don't have a solution but I also have the same probem with my 760. It worked for 5 years, then the problems started. What a pain! I replaced the water panel, cleaned out any calcum buildup, etc and no luck. There must be a defect!
If I can't solve the problem sooon I will buy any brand of humidifier but Aprilaire.
Posted on Nov 18, 2008
  • 140 Answers
SOURCE: Water coming from inside unit of Fujitsu airconditioner
Go to http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=36 to get the manual. Any questions please ask. Please rate me so I know if I helped.
Posted on Dec 30, 2008
  • 45 Answers
SOURCE: Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Posted on Jun 09, 2009
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
Kelvinator 330 impression series fridge leaks water internally and runs on to bottom shelf. I cannot see where it is dripping from, the drain rack is clear as is the cooling component. This is a regular...
The drip tray is blocked, open your door, about half way down at the back you can see the drip try, on the Right hand side there is a hole where the water drains, poke a plastic straw down there to clear.
Feb 26, 2010 | Refrigerators
I have a coolant leak coming from my 1988 f150. I thought it was because of a bad hose, so I replaced the hoses on the top and bottom of the radiator, but it is still dripping. It sort of looks like the...
The bottom hose goes to the water pump and I would bet your leak is coming from the water pump. The water pump leaking mean it is going bad and needs to be replaced soon. Definitely not as bad as a cracked block.
Oct 10, 2009 | 1988 Ford F 150
Water is leaking from the bottom of the fridge. Why? It is destroying the wooden floor. Refrigerator is Whirlpool Model # ED25UEXHW01
Some water dripping under the refrigerator is normal. There is supposed to be a drip tray to collect it, and there is not so much that it can't evaporate. Check to see that the tray is still there, in the right place, and not cracked. If the drip tray is full of water, then you have another problem. If your air is humid, you would get more water during the defrost cycle and the water in the drip tray wouldn't evaporate very fast. If your freezer door seal is not air tight, you would get more water to defrost. My guess is, the drip tray is out of place or cracked.
Sep 11, 2009 | Refrigerators
Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Nov 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Replacement
Remove the front panel, & look for the drain tube that runs from the drip pan under the cold coil. It is likely blocked & may be cleared with a piece of coathanger wire. Be gentle.
May 08, 2007 | Panasonic CW-1006FU Air Conditioner
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
