Question about Grilling
Lagermania model t1720 super,is there some kind of seal or o-ring between the gas jet (at the gas control knob) and the tube going to the burner?
catriver
  • 878 Answers
SOURCE: Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Posted on Mar 03, 2007
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
SOURCE: Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Posted on Sep 20, 2008
  • 75 Answers
SOURCE: When control knob in"pilot" position, burners light
It has a thermo-couple that lets the gas valve know that the pilot light is on. If it does not get the heat signal to the valve, it will not turn on the gas. The end of the thermo-couple has to be in the flame of the pilot, and tight on the other end, and must be tight on the other end.
Posted on Dec 21, 2008
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
Where do I find the orface and air intake on the GE Range
Sealed burner ranges the orifice is in the center of each burner, down inside(brass color). Open style burners the orifice should be under the lift off burner or in some case where the burner tube goes back to the control panel at the control knob. Almost all will be brass color. Oven orifices are at the end of the burner tube where the gas would come into the burner. Air adjustments are usually right near the orifices. A small sliding window with 1 screw holding the adjustment in place.
Mar 23, 2015 | GE 30" Self-Cleaning Freestanding Gas...
Model 141.163211 Kenmore BBQ Grill. Burner tube ignites then after a few seconds flames ignite behind control panel - melted knobs. A year ago same problem. Removed all parts and cleaned, installed new...
It sounds like sealant may need to be used on connections. Use appropriate one for gas fittings.
Noting where the leak is occuring is important. Another possibility is the fuel is being somehow "jetted" from a hole or orifice in a burner tube to the area behind the control panel. These are hard to see what happens first when it does happen.
Nov 07, 2009 | Kenmore 16322
4 burner gas cooktop leaking small amount of gas at front burners and underneath the knob controls. Flame now licks above the bottom of the pan.
Hi, It sounds like the tubing to the burner has got a leak in it. Please get me a model # so I cna look this up and give you better instruction on how to get to the tubing.
Vic
Jul 01, 2009 | Cooktops
Steps in replacing 5 burners on Ducane burner mod 30400042
First calll Weber to get your replacement burners for free. There is a five year warranty on this model which is a little over 4 years old. I know this because I just received them from Weber for free.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400042 (LP)
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Jun 07, 2009 | Ducane 30400042 (LP)
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Apr 16, 2009 | Ducane 30400042 (LP)
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Avanti DG241BS - oven will not stay on
There has to be a protection system in the burner assembly to cut the supply of gas to the burner if it does not light. For the case of an oven the supply must be cut off immediately if the burner and its pilot go out. For that gas control system to work the burner control must "recognize" with a sensor when the burner is lit and when it is not. Pushing the knob "in" momentarily on this model bypasses the protection system momentarily to allow a burner to be ignited in the first place. If releasing the knob extinguishes the flame the control system is not "seeing" the flame. I tried to find some detail info on you particular ignition system but to no avail so all I can offer is a general approach to these kinds of problems . You need to find and clean or replace the sensor used to detect a flame. It could be an optical one (doubt that) or a temperature flame sensor, a thermocouple sensor, or some other kind I haven't thought of. Fixing this problem involves first determining what kind of sensor it uses. A copy of a service manual for this model can help you determine that. Try to clean the flame detector, and if that doesn't work you have to replace it or the gas control assembly it is a part of. If you have a spark ignition and its not sparking when it should first clean it --carefully--. Spilled food can short them out. Unplug the range before doing this. The owners manual shows it to be under the top burners which can be removed for cleaning this.
Aug 07, 2007 | Avanti DG241BS Stainless Steel Gas Kitchen...
Grilling Logo
41 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
