Question about Magellan Maestro 4040 GPS Receiver
No sound meastro 4040 gps
No sound at all!
  • 32 Answers
Did you go to USER OPTIONS Select SYSTEM SETTINGS Check the VOLUME setting. If this don't work then try pressing the RESET button on bottom of unit on left side. That's all I know other than contacting Magellan customer service
Posted on Jan 21, 2009
I have lost sound/voice on my magellan maestro 4040 after replacing battery. Any ideas?
either you forgot to plug the speaker back in or you damaged the headphone jack...if the jack is messed up (the contacts to the board are ripped) you can buy a traffic cradle to bypass the headphone jack which will solve your problem
Bill
Standing Member of G.O.T.
Nov 05, 2011 | Magellan Maestro 4040 GPS Receiver
How do I change the battery in my magellan meastro 4040. Sidney Walker swalker@wavecable.com
www.magellangps.com/assets/manuals/maestro_4040_manual_en.pdf
it is all revealed in this manual above please download and read how to.
Aug 09, 2010 | Magellan Maestro 4040 GPS Receiver
How do I remove the cover of the magellan maestro 4040 gps
the 4040 only comes apart one way without breaking off the power and headphone port...the video in the previous solution is not a 4040 as listed...its a 4250 and totally differant from a 4040...if you havent taken this apart yet, please let me know so i can tell you the proper way before you ruin your very expensive 4040...
im also going to ask (flag) the previous answer to be removed because its not even close.
bill
Apr 27, 2010 | Magellan Maestro 4040 GPS Receiver
Are there any free updates for a magellan gps 4040
  • The only free update for your 4040 is the latest firmware or you can call the tech support of Magellan and ask if you can still avail the latest maps for your 4040 don't forget the recepit when you call them, they may ask you to send it to them for verification.
Feb 10, 2010 | Magellan Maestro 4040 GPS Receiver
No sound on magellan maestro 4040
if the sound is enabled and not muted, a reset will normally fix the problem. find the littlew pin hole on the side, start the 4040 and then insert a paper clip in the hole to reset it and wait for it to reboot. it should be ok now, but in rare cases you might have to update it if you havent already. you can get the update HERE49181cd.gif
let me know if you need further help.
bill
Sep 04, 2009 | Magellan Maestro 4040 GPS Receiver
Meastro 4040 wont charge reliably
I had the same trouble exactly. The yellow power input socket has a pin and shield connection that must be contacting the center and side of the power input plug. I opened the Magellan and found that one side of the shield contact had never been soldered to the PC board. It was only a matter of time and use, before the piece moved up and away from the outer part of the power socket. A dot of solder solved the problem. The case for the Magellan is easily opened by removing four very small screws from the four corners of the black back and then prying the silver framed screen from the back exposing the printed circuit board. I am sure this completely voids the warranty with Magellan, but they will not repair out of warranty units anyway. Be aware there is a connector from the screen that is plugged into the circuit board. This is easily pulled apart with a pair of fine needle nose pliers and replaced the same way after the repair. The soldering should be done by someone with PC board assembly experiance.
Handy John
Feb 21, 2009 | Magellan Maestro 4040 GPS Receiver
Broken screen
my best subjection is ebay.com
Good luck
"Was this helpful?"
Feb 15, 2009 | Magellan Maestro 4040 GPS Receiver
Traffic kit
HI,
Let me say u that the maestro 4050 - Comes with the preloaded traffic kit with free 3 month subscription period .
But the maestro 4040 - does not comes with the preloaded traffic kit.If u want the traffic kit You have to purchases .
So both the 4040 and the 4050 is compatable with the traffic kit........
Jan 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
105 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
