Question about Dryers
Beko DRVS62W not heating
Changed drive belt and now drum goes round but no heat! Any help you guys?
SOURCE: Beko tumble dryer not drying.
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
AlmostBob
  • 550 Answers
SOURCE: BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Posted on Aug 28, 2008
SOURCE: Hoover nextra mega load 7.5kg
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Posted on Jan 05, 2009
protek480
  • 1714 Answers
SOURCE: tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Posted on Jul 07, 2009
  • 36 Answers
SOURCE: my drumb not going round , had new belt 4 months
It sounds like the belt may have slipped off of the tentioner, or the motor seized up .. always unplug the dryer...
Posted on Oct 12, 2009
Testimonial: "thank you x"
Hi I'm getting no heat from my beko drvt 61 w tumble dryer, have replaced the front thermostat, heating element and cleaned filter at front but still no luck is there any more I can do?
Did you check fuse that might be near mains entry into the machine ? Why did you replace the heating element ?
is rest of machine working ?like fan motor running ?
sens more details so that I can pin point the trouble.
Oct 03, 2015 | Beko Official Drvs62w Belt Poly V - 1967...
My hubby put a new belt on our beko drvs73 timble
maybe he pulled a wire off of thermstat or lid switch....
Aug 28, 2014 | Dryers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Drvs62w drum revolves but not heating
Heat element or stats check first after that timer .
motor can also cause no heat switch on motor
b4 anything check power one side of the 220 power may be down flip you home breakers
Dec 02, 2013 | Dryers
WIRING DIAGRAM BEKO DRVS62W
Hi i took the front pannel of my beko drvs62w dryer to replace a button and for gote what colour wire gose where on the bk of the power button can anyone help please
Nov 09, 2012 | Dryers
Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
Jun 27, 2012 | Beko Washing Machines
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
