Question about Kenmore 23822 Top Load Washer
Vibrating on spin cycle.
Washer vibrates when spinning out. Its level and clothes are level inside inside. Why?
  • 126 Answers
If the machine is new there is a possibility that the shipping pin didn't come out completely. If you set the machine up yourself, there is a yellow plastic strap that holds in the electric plug. You need to pull, not cut this plastic strap as it has a pin that is about 8-10" long that goes through under the tub to secure the machine for shipping.
Posted on Jan 20, 2009
On the spin cycle my samsung front load washer wibbles and vibrates badly. I have replaced the shocks but that didn't work. What else could it be?
Check that it is level and that all the water is draining out when the wash cycle is complete. Check that the wash drum and all associated parts are correctly in place and are secure. Check the drum for excessive play, replace defective parts.
Also look for loose objects from clothing that may be jammed out of site but causing centrifugal throwout vibration.
Feb 17, 2015 | Samsung 3.7 cu. ft. High Efficiency Vrt...
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Top loading washer vibrates quite a lot during spin cycle
If the machine is level and the feet are properly touching the pads it may be a fault in one of the suspension components or it could simply be the way the load is sitting in the machine during spin cycle. Towels get heavy when soaked and if the load is not balanced inside it will make the machine vibrate. Have you tried the machine without any clothes in it to rule that out?
Dec 27, 2012 | GE Washing Machines
I have a new (had it two weeks) GHW9150HP and now the clothes are soaked like they did not go through the spin cycle. The washer also seems do not be level since is vibrates so mch that is 'wonders'...
As far as the vibration goes, check to make sure that the machine is leveled. Also check to make sure that the shipping bolts have been removed. On every spin cycle, the machine goes the a process to check if it is balanced or not. If the machine senses that it is unbalanced, it will stop the cycle. So that could be why your clothes are coming out soaked. try this solution first, if the problem continues, let me know and we can try a different solution, perhaps putting your machine in diagnostic mode.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Kenmore 23822 Top Load Washer Logo
79 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
