Question about Whirlpool Washing Machines
F13 error on whirlpool washing machine, model no wfe1485bd
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Got a whirlpool washing machine the door wont open
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Whirlpool washer wfe1485bd error code F08 what does this mean and is it easy fixed
It means there's not enough water supply pull the hoses and check the screens and make sure no dir is trapped in them
Jan 03, 2015 | Washing Machines
Whirlpool washing machine wfe 1075 bd error code f13
I had the same problem and looked on other forums.
Many people had said they had success simply giving the door a moderately hard thump! I was skeptical, but prepared to give it a go, so I administered a swift kick to the door.
Lights and action, everything back to normal. Hilarious! This seriously worked - at least give it a go before you bother with anything fiddly or expensive.
Apparently this model has issues with faulty door locking.
Jan 14, 2012 | Whirlpool Washing Machines
Whirlpool 6th sense Finished wash, then noticed strange read out on front with red ? it said f13. Cant find trouble shooting manual,then i turned dial to off position now no power to machine, Changed fuse...
In my list for Whirlpool, 'F13' stands for 'Dispenser circuit error' - requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 01, 2011 | Whirlpool Washing Machines
F13 and door not opening washing stuck ith cage .
Hi
F13 is a door lock error which means that the door lock is bad and should be replaced. To unlock the door you can leave it unplugged for around 10 minutes and the door will unlock. Hope this helps...please post back for further assistance.
Daniel
May 10, 2011 | Whirlpool AWOE8748 Front Load Washer
My mum's AWOE8748 shows F13 it is only just over 1 year old how can I fix it.
Hi. The F13 error code indicates a problem with the doorlock mechanism.
Whirlpool have identified issues with some models and door lock errors so it may be adviseable for you to contact whirlpool customer services.
The error can lead to the door jamming shut.
First of all open the door, if you can, and check that the lock latch on the door is level with the door lock hole on the front panel of the machine. Sometimes you can accidently lean on the door when putting in or taking out the washing sending the lever and hole out of alignment. You can put pressure on the door to align it either way if not level. If you need more help then repost.
What area are you in?
Jan 25, 2011 | Whirlpool AWOE8748 Front Load Washer
AWOE9558 Whirlpool Washing machine is displaying a F13 code! Please Help! It wont open the door or finish the wash, what do I do? Thank you
F13 is usually a dispenser circuit error, which means the dispenser motor is not able to move to its proper position.
This maybe because the dispenser motor has failed or the mechanical link from the dispenser to the motor is broken or the wiring to the dispenser motor has become detached.
Try pushing the dispenser door closed more and see if that has any effect otherwise i think you will need a repair man.
Nov 30, 2010 | Whirlpool GHW9400 Front Load Washer
Got a whirlpool washing machine the door wont open and on the display it says f13
Jul 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Washing Machines Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
