Question about Admiral AW22 Top Load Washer
The washer runs threw the cycles but drum wont spin
If you push the drum to one side it will spin while on
  • 126 Answers
If it is a topload whirlpool or kenmore, you may need a new lidswitch or motor coupler. What do you mean you push the drum to one side?
Posted on Jan 20, 2009
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Water pores out on spin
Take off the cover and check for any holes in the top of the plastic tub surrounding the drum . This can occur when the washer is or was previously severely out of balance and the drum rubs a hole in the side of the tub. Since the water is usually below this level until the spin cycle pushes the water up the sides of the tub, it only becomes apparent then. Another possibility is there may be a blockage in the pump or drain hose. If you still have a good amount of water in the tub due to the washer not draining completely before the spin cycle, the water will sling everywhere when it attempts to spin. I hope this helps! Good luck!
Feb 21, 2012 | Washing Machines
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
ASKO washer WL6511XXLPP
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing.
ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, strongly encouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
Mar 22, 2009 | Asko WL6511W Front Load Washer
Washer washes and wont spin clothes in either the wash or rinse cycle
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Admiral AW22 Top Load Washer Logo
101 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
