Question about Mercedes E-class Pillar Posts Trim Set
The heater doesnt get warm
The heater dont get warm
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
LOW ON COOLANT!!
Posted on Nov 15, 2013
My 2006 e350 mercedes heater dont get warm
Could be thermostat, Heater Core, or variouse other issues, could use more info, smells, noises, visuals, ect.
Jan 08, 2013 | Mercedes E-class Pillar Posts Trim Set
I have a 2002 gallant and the heat doesnt blow warm air..any thoughts?
Make sure that the radiator is full and if you still dont have hot air then check to see if the top rad hose and the bottom rad hose are hot after driving for 30 minutes. Now if the bottom rad hose is not as hot as the top hose then replace the thermostat. If both the hoses are hot then check the two hoses going into heater core at the fire wall, both of the hoses should be hot, if not then problem is in the heater core.
Nov 08, 2011 | Cars & Trucks
My 1999 ford taurus heater doesnt work. We recently had a problem with the reservoir boiling over and brown coolant. Had the thermostat replaced and replaced the radiator cap. Also flushed the radiator....
Sounds like the heater core may be blocked..First check the level make sure its full..Then let the vehicle get up to operating temperature..Feel the heater hoses going into the firewall..Both should be hot to touch..If one is hot and the other one is warm or not warm ,,then you have a blockage in the heater core..If its block ,,then i have cleaned them out by taking the heater hoses off,,and running a garden hose through the heater core..If that doesnt work then you have to remove the dash,,and replace the heater core..
Sep 24, 2011 | 1999 Ford Taurus
Cadet C151 heater not producing warm air.
take your tstat off jump out the wires red green white together. if it works like that then your thermostat is bad. if it doesnt then it is in the unit.
Mar 24, 2010 | Cadet Manufacturing Com-Pak Plus C151...
1988 bmw 325i heater blower fan
Had my blower replaced last year, but my heat does not work. I can turn it up to 91 degrees and it is barely warm. Help please.
Feb 10, 2010 | 1988 BMW 3 Series
Heater wont heat
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
Oct 01, 2009 | Honeywell HZ519 Baseboard Heater
Ford ka blows hot air even set at cold
sounds like heater control valve situated under scullle panel common fault on ka set heater fan switch half way between hot and cold with heater blowing then touch valve if pulsing or clicking noise it is faulty if doesnt solve problem faulty switch
Jun 07, 2009 | 1999 Ford Taurus
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Mercedes E-class  Pillar Posts Trim Set Logo
82 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
