Question about Dayton Electric Heater
Dayton 3ph 208V heater # 2yu72 not firing off - WHY?
Hello - let me get to the point. I am an electrician and have replaced the contactor at the belly of the unit due to overheating and one of the phase wires dissconnecting from the contactor by melting. I bypassed the contactor by sliding up the manual contactor override and the unit works fine. Everything checks out with the thermostat but it still will not fire off. Just wondering what else I should be looking for to get this thing going and me on to another project. Any help would be greatly appreciated!! Thank you againg for your time.
  • 462 Answers
I assume you mean its not Heating by not firing? If its 3 phase you may have lost 2/3's of your heat not just 1/3. Look at the safety's and find if 1 or more are open. Also there is a fuse able link on most elements and if you have had the heater try to run without a blower lately (or anytime in the past) the link may be out. These are usually installed where they "see" the heaters. If you have power to all the elements look for this or a bad element(s).
If your contactor is still not pulling in check for open safety's or bad timer.
Posted on Mar 04, 2009
  • john094 Jan 18, 2011
    I too am an electrician as the above comments. I have the same problem with one phase wire melting off, is this an ongoing problem? I would like to replace the contactor, Can you tell me where I can buy one? John
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
NEED a wiring Diagram for a Dayton 3hp motor model # 5K967M is there anyone out there that can help me
you don't need a wiring diagram for 3ph. this motor is single phase. either 120 or 240v. you just need to fing out what power you will power it with and read the inside cover for the wiring box on the motor. given to you by an electrician w/35 yrs experience.
Mar 08, 2011 | Kitchen Ranges
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Oct 10, 2010 | Dayton D-F79 Electric Space Heater- the...
I have a 6a859 relay, does the 120 power lead go on 2 or 3?
Your load cannot exceed 1 amp
You'll need to connect load wires to a contactor or relay that has 120V coil
Local HVAC supply carries contactors
Grainger has contactors 120V coil and 25 amp across terminals
Fasco H230A with 120V coil and 30 amp across terminals
Sep 19, 2010 | Amperite Dayton Solid State Timer On Delay...
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
Can the G73 be hooked up to an wall thermostat and allow it to over ride the unit thermostat? I want to install this is in a greenhouse and would like to have the thermostat on the wall down lower and not...
Yes, but it will require some knowledge of electric to do that. You will need a line voltage thermostat and mostly like have to have that run a contactor that will be wired to bypass the heater thermostat. A good electrician should be able to to this for you very easily.
Nov 09, 2009 | Dayton G73 Utility Heater
Have 2 of these heaters 2yu65 and contactor constantly tripps on and off if i by pass limit overheat cutout they work fine
you should not jump out high limits they are there to prevent fire .if it is opening there is a reason
Apr 06, 2009 | Dayton Electric Heater
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Heating a 300 sq ft room to 125-135
What is the activity in this room is it and interior room how many exterior walls and what is the winter climate like where you are located.
May 23, 2008 | Dayton (4LX41) Heater
Dayton Electric Heater Logo
230 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
