Question about Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper
Can i turn the fax machine off on my Philips Magic 5 voice dect?
I am receiving loads of unwanted spam faxes which are using up my ink film rolls. Can I turn the fax to a manual setting so that I can only recieve faxes that I want and [obviously] am expecting? -ie the person calls me to say they are sending a fax, and i then switch to fax mode for that one fax.
  • fotini76gr Jan 21, 2009
    I think that you must turn it in the phone mode and when the call you for sending you fax to turn it in the fax mode. Try it.
    Efi Greece
I think that you must turn the machine in the phone mode. So, when you want to receive the fax
the only thing that you have to do is to turn it in to fax mode or press the start.
Posted on Jan 21, 2009
Fax memory says full. how do you get them(Panasonic KX-FG2451)I haven't been able to receive faxes, don't know if this would effect it.
The memory is full of received documents due to a
lack of recording paper, a lack of ink film or a
recording paper jam. Install paper (page 13), install
ink film (page 11) or remove the jammed paper
(page 63).
the entire manual here http://service.us.panasonic.com/OPERMANPDF/KXFG2451.PDF#page=53
Apr 17, 2009 | Panasonic KX-FG2451 Fax
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Philips fax machine inkroll film replacement
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
May 07, 2008 | Philips PPF-531 Plain Paper Thermal...
New ink roll in Philips fax Magic 2
Here is what you do
OPEN MACHINE
CLOSE MACHINE
SET TIME AND DATE
OK
OPEN MACHINE
CLOSE MACHINE
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper Logo
351 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
