Question about Diamond Multimedia Computers & Internet
Diamond Raedon 7870 fuzzy screen after drivers
Hello I just recently ordered and received a Diamond Raedon 7870. I'm using a 42" 1080p Tv as my display, Before I installed my drivers my display looked very clean clear and sharp. After installing the latest catalyst drivers and rebooting, My screen is overscanned and very fuzzy and blurry. I decided to go into the engine control center and change the underscan back to 6% so it fits. But now the issue remains is the fuzzy blur, What is causing this issue? Obviously the card cannot be messed up but the drivers are somehow causing issues. My specs are - Windows 7 64 bit - Os Amd Phenom x4 965 BE - Cpu m5a78l-m lx plus - Motherboard Raedon 7870 "diamond brand" - Gpu Seasonic x650 gold - Psu 4 gigs of ddr3 1333mhz - RAM Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Diamond Mult... Master
  • 1,745 Answers
You'd better to revert driver changes
Posted on Mar 27, 2017
SOURCE: screen shut down
hi furotte,
u have taken a right decision u havt to buy a new graphic cards while buying card just read the manual of cod4 it shows the latest graphics that supports the manual will be in cod4 game file
regards
shailesh
Posted on Mar 13, 2008
sparky1500
  • 1066 Answers
SOURCE: Nvidia 8800 GT Gigabyte graphics card doesn't have any resolution options.
did you download the latest motherboard drivers? has the video card ever worked?
Posted on May 29, 2008
  • 154 Answers
SOURCE: I just installed a xfx
Its a driver issue. Download and install the latest drivers for the XFX card and *********** board. That should fix it.
Cheers.
Posted on Mar 19, 2011
  • 57 Answers
SOURCE: Trying to install ATI FireMV
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Posted on Apr 14, 2011
bronk50
  • 27725 Answers
SOURCE: I've installed a diamond stealth
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers hope this helps
Posted on May 29, 2011
All I can get is a white fuzzy screen neither remote will work
I saw your post, kimlucasmill, and wanted to help you get that fixed! If you're using an HDMI cable for the connection between the receiver and TV, make sure the TV is on the HDMI input. If it's a component or AV cable, make sure it's on the respective input of those two. In the event that you're using anything other than those, such as a basic coax cable, make sure the TV is on the correct channel, perhaps channel 3.
Hope that helps!
Sep 18, 2011 | DISH Network IR Remote Control
We have a Diamond Vision TV/DVD and the remote does not work. Is there a contact email or 1-800 number I can call to order a replacement one?
Diamond Vision is actually manufactured by Mitsubishi, so you can use this website to figure out the remote model # using your TV's model #. Then you can call the 1800 number listed on the top of the page to order it :)
Jul 18, 2011 | Televison & Video
I just received the Diamond VC600 video capture device...but noticed it is compatible with Windows Vista. Before opening the package, what about Windows 7? Will I need to download additional drivers, or...
I have not had problems using the VC600 with Windows 7 32-bit or 7 64-bit. If you have problems installing the drivers for the device, either have windows search for updates or install the drivers manually within Device Manager by doing an Update Software on the unknown devices and use the XP 64-bit drivers on the disc. If you still have problems with the device, I would contact the manufacturer's Technical Support center to see if they can help you out with the install.
Nov 14, 2010 | Diamond Multimedia Diamond VC600 One Touch...
Mits TV blue Screen
I fortuneatly bought a 4 yr warranty from Best Buy on my Mits. same thing happened with the blue screen fuzzy white diamond. The geek squad techie showed me the 2 capacitors that go bad on the power board and he ordered them and once they were replaced the TV worked perfect again. I have 2 weeks left on the warranty, so i'm calling them today to get my last free bulb(screen is kinda darkening, kinda) hopefully i can convince the technician. This was one warranty that bad for itself.
if you have any electronic skills you can replace these capacitors yourself, once you get into the guts of your unit.
Good Luck
Oct 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Dec 23, 2007 | Atari 2600 Console
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Computers & Internet Logo
75 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Jason Harris
Jason Harris
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
