Question about Baumatic Washing Machines
Baumatic top loader bk6el 6kg goes off balance
My washing machine keeps shaking and wobbling during the spin cycle. I try and balance the load evenly. It sometimes stops mid spin cycle and I have to rebalance and start again.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
  • 135 Answers
SOURCE: Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Posted on Jan 23, 2009
  • 225 Answers
SOURCE: Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
Posted on May 02, 2009
SOURCE: re Baumatic BK6EL, the washer stops at the
Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
Posted on Mar 02, 2010
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Re Baumatic BK6EL, the washer stops at the beginning of the spin cycle, showing soak, extra rinse, spin lights all on. Thinking it was just an unbalanced load, I readjust the load and press the start...
Oct 27, 2009 | Washing Machines
Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Sep 16, 2009 | Maytag MAH8700A Front Load Washer
Need a manual for the Baumatic BK6EL/6kg just bought off Trademe no manual with machine
www.baumatic.co.uk
Should be contact information here to request (or possibly download) a manual.
Apr 19, 2009 | Baumatic Washing Machines
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
Jan 16, 2009 | GE Washing Machines
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
