Question about Vizio Gallevia GV42LF 42 in. LCD Television
Inconsistant dark screen vizio GV47L - Vizio Gallevia GV42LF 42 in. LCD Television
I agree with the above. You will need the main board. I have the boards for this tv if you're interested in purchasing them. My vizio took a remote to the screen. Let me know if i can help. Shoot me an email.
Johnny
Buymytvpleez@hotmail.com
Posted on Jan 09, 2013
5 Suggested Answers
  • 10 Answers
SOURCE: I CAN TURN THE POWER ON. THE SCREEN STAYS BLACK.
This TV has 2 main circuit boards (2 LCD backlight controlers): the Power Supply board may have fried the video board on it's way out ...
You can either arange to have the TV replaced under warenty if not have it serviced. In any case best of luck with Vizio support line.
Everyone bought this TV because it was so cheap... now we find out why: Vizio cuts corners on everything from engineering to support!! All brands are not created equal. Sometimes you get what you pay for.
Posted on Feb 25, 2009
  • 11 Answers
SOURCE: vizio gv47l lcd a popping sound and tv when dark and no sound
This sounds like a main board issue to me.
Posted on Jul 29, 2010
eagle338
  • 4889 Answers
SOURCE: vizio gv47l lcd failed with loud popping sound and
What about sound? Do you have sound?
Posted on Nov 23, 2010
  • 11800 Answers
SOURCE: Hi. My 47" Vizio GV47L
The amber light signals that the power source is in protected mode - the source is practically closed down by force and no longer delivers not even the stand-by voltage to minimally power the processor (hence the remote issue). This happens when one of the other boards in the tv is completely shorted.
Just 2 boards are capable of triggering that when they fail: the power source itself (one of its output transformers or rectifiers have failed) or the inverter/ballast boards (2 of them) - the ones that power the tubes that light up the screen.
To find out which you must disconnect the inverter boards and see if the tv starts up - if the tv starts and you can hear sound (and probably see an image if you light up the screen with a flash light) then the inverter board is faulty and you will have to replace it. If it doesn't then the power board is damaged and the inverter might have caused that - further testing on the components on both boards is needed to determine what caused it. A good experience in repairing electronics is required for that or you will replace boards blindly and hoping for the best
http://www.tvpartsguy.com/servlet/the-34/VIZIO-GV46L-INVERTER-Model%23/Detail
http://www.partstore.com/Part/Vizio/Vizio/GV47L/Vizio/Vizio/050005070260R/New.aspx
Posted on Apr 30, 2011
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
May 17, 2013 | Televison & Video
Vizio gv47l black screen
The inverter is usually the cause if you have perfect audio but the screen is black. You can get inverter boards from www.tvcircuitboards.com
Jan 12, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
My vizio gv47l went black. where do i start
Search on blown fuses for gv47l. There are three fuses that you can check (open the back of the TV) and if one is mad you can jumper it with another fuse. I did this nad it fixed my gv47l
Dec 03, 2010 | Vizio GV47LF Television
Vizio GV47L, How to replace fuses on motherboard? I have the fuses located, but never swapped these type of fuses before. Thanks
Fixed my 47" GV47L for $7.18... Did the F3 Fuse bypass solution, and it worked like a champ!!! No problems since! The part that took the longest was the drive to Radio Shack!!!r_to_the_k.jpg
Jun 03, 2009 | Vizio VO47L 47 in. LCD TV
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
Feb 09, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
71 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
