Question about Kenmore 24032\24036 Top Load Washer
My washer quit using water. no water get inside
    Problem Solver:
  • 8 Answers
The water inlet valve could be malfunctioning or the screen at the hose fitting could be clogged. Check screen or replace valve on back of washer were the hoses connect.
Posted on Jan 22, 2009
I have a 2005 astra 1.7 cdti design and cannot work out how to work the rear windscreen washer or where the filler is.
You press the washer stalk to operate the rear washer but quite commonly the washer jet blocks up and will not release water.
You need to use a pin to try & unblock it. If this doesn't work (and it probably will not) you need to remove the trim on the inside of the boot, unclip the high level brake light & wash out the nozzle with warm water.
Nov 29, 2015 | Cars & Trucks
Maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
When empty, I can turn inside and sounds like there is water sloshing inside
This is not a problem actually. That is quite normal for top load washers. What happens is when the pump comes on to expel the used water it only runs long enough to empty the inner drum. The outer drum still has a little bit of water inside to act as a pea trap of sorts. This keeps undesirable smells from reentering your pipes and causing bad Oder's in your home. As long as your cloths come out clean and partially dried from the spin cycle then your washer is working correctly. Hope this helps. Good luck.
Mar 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
The place where hot and cold water go into the machine is leaking water.
hi ,
the hot and cold hoses should have a small rubber washer inside the coupling , it is quite common for these to fall out when the machine has been disconnected ,also the couplings which are made of a plastic material are quite fragile and can be easily split or cracked by over tightening them ., the solution is to replace the rubber washers , or replace the entire hoses
hope this helps
Jan 10, 2010 | Washing Machines
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
Rust inside my washer
Use Oxylic Acid Crystals dissolved in hot water and test for color fast if applicable, carpets, clothes, washer, toilet, surfaces, etc. Oxcylic acid is a white crystaline acid which reacts specifically with Ferric Oxide, (rust) and oxidises the stain quite selectively. Few teasthingys in a small bowl of hot water and a toothbrush. Purchase cheap at local hardwares Hope this Helps Let me Know Ttech
Jul 24, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
