Question about Whirlpool Washing Machines
Suds remain after rinse
Use all mighty pacs
2 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Suds in rinse water
I would check for a cold water supply problem since cold water is supposed to be what is used in the rinse cycle. If only hot water is being supplied it would explain the suds thing. I would take a look at the water inlet valve and would pay particular attention to the cold water side. Unplug the machine and remove the supply hoses. Check the small metal screens inside the openings on the water inlet valve and make sure they are clear of rust or debris. Next, check the solenoids using a multimeter or ohmmeter and test for continuity. A lack of continuity would indicate a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
It move to rinse to spin then back to rinse
If you use too much detergent and get a lot of suds, some models rinse again to remove the suds. It will display "SUDS", normally at the end of the cycle.
Mar 27, 2015 | Maytag Washing Machines
I have a ge tl washer model number whre5260e1ww and it's not rinsing all the suds out. One day I rinsed the same load of towels 9 times and still had suds. Any ideas?
How much soap did you use? During the final spin, your "final rinse" lets water into the tub to rinse out any remaining soap. Check to see how long it rinses for. If it is very briefly (a few seconds), there might be a problem with the timer or the electronic water inlet solenoid. The solenoid is what opens the valve to let the water in. Sometimes when they go bad, they won't let the valve stay open long enough to let enough water in.
May 11, 2012 | GE Washing Machines
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
I have an HE 5T Steam Front Loading Automatic Washer. It is showing Sud indication, nothing seems like happening and after few minutes it will show F35. What does it mean?
Hello again,
I found your manual. If you like to get it, go HERE. This is what it says about "SUDS" action:
Near the bottom of the troubleshooting page, it gives this for errors:
It doesn't specifically state what "F35" is, so I can only suggest these steps, and see if this solves your problem. If it doesn't I would be inclined to believe that there is a problem with a part, which would probably be serviceable by a tech from Sears or their partner service company.
Hope this clears it up for you.
Please rate and comment. Thank You
Joe
Sep 02, 2011 | Kenmore Washing Machines
I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
yes it will foam up unlike you have never seen before
by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Dishwasher not draining completely-suds left
Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
SD error code won't go away
Manual says -
"Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended
for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's
directions.
If excessive suds are detected, the washer will display this
code while running a suds reduction correction routine at the
end of the wash cycle. The suds reduction routine removes
extra suds and assures proper rinsing of your garments. If the
code remains and the wash cycle dial is flashing after the
recovery routine has stopped, re-select your desired cycle
using cold water. Press START. Do not add detergent.
Let me know if this helps, or you would like more information/help.
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
