Question about Xerox FaxCentre F110 Plain Paper Laser
To not receive faxes
I need to turn it off where I can only send faxes
    Genius:
  • 2,120 Answers
Set the fax to MANUAL RECEIVE
Posted on Jan 24, 2009
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Do not know how to turn on "receive faxes". can only send faxes. How do I turn on receive faxes?
if you are able to send faxes it means you are set up correctly, meaning that you have connected your printer/fax machine up correctly to the phone lines. all you need to do is make sure the printer/fax is on while you are receiving the fax, there is no "fax receive mode" however, you need to know that if you use the same line for your phone and for your fax that your phone will ring when receiving a fax, if you answer it will ruin the fax, there is a special configuration you can access which will let your printer work more effectively, such as to intercept faxes and immediately process them before letting your phone ring, or waiting a certain amount of time or such. you can consult the specifications of your device to know the exact settings you have available.
Apr 15, 2011 | Canon PIXMA MX870 Wireless Office...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax machine will send faxes but will not receive any
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Apr 11, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Xerox FaxCentre F110 Plain Paper Laser Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
