Question about Dryers
Maytag de608 dryer won't start
Upon depressing the start control, thereis only a whirring clicking sound.
  • 213 Answers
SOURCE: maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Posted on Nov 25, 2007
SOURCE: Maytag performa dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Posted on Jul 04, 2008
Healeyman
  • 1198 Answers
SOURCE: maytag dryer lde 313
Check the belt.
Posted on Apr 28, 2009
bozcro
  • 867 Answers
SOURCE: dryer does not come on. licking sound when i push
starter relay switch needs replacing
Posted on Jun 27, 2009
  • 10 Answers
SOURCE: I have a Maytag Model DE608 dryer and all of a
Fantastic dryer!!
Several things come to mind. Cycling thermostat, heating coil, electronic control unit. If you know your way around a multimeter, I could further help you out.
Posted on Oct 01, 2009
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
When I push the start button I only get a whirring noise on any of the settings and the machine won't start.
This could be the motor turning but the belt being broken. If you are mechanical inclined, you can investigate the inside of the machine, and see if the belt is broken. Replacement is not too difficult.
Any questions and I'll be more than happy to give more instruction
Joe
Sep 06, 2011 | Maytag Dryers
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
MAYTAG BRAVOS DRYER CODES FLO, CO WON'T START AFTER STORM
I have the same problem. Technician recommended to replace main control board - didn't help. Now I ordered the user interface board. The self test results in C0 code which stays till reset.
Jul 04, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
I have a Maytag Model DE608 dryer and all of a sudden it is not heating. What could be causing this?
Fantastic dryer!!
Oct 01, 2009 | Maytag Dryers
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Dryers Logo
14 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
