Question about Cooktops
Need a wiring manual for 89890 jennair cook top
3 Suggested Answers
  • 744 Answers
SOURCE: I need a grease filter for my JennAir cook top it
See the link below, then click on the exact model number for your appliance when the page appears. Then see the specific section for the part you require:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JED8130
Posted on Apr 02, 2011
  • 5370 Answers
SOURCE: My electric jennair down draft
It can be short in control board.The weak components on the board gets shot.Actually as you mentioned that circuit breaker tripped.When the components gets weak and board cannot handle the flow of current, at that time it trips the breaker, so that components don't get shorted.But if still the circuit breakers is turned on, then in some cases the breaker trips again or in some cases the weak components on the main control board gets popped out and unit quits working.------- As per the problem mentioned the main control board has top be replaced. But still get the voltage checked at the board.This will help.----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Posted on Jun 30, 2011
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Jennair electic cook top
Buy whatever kind you prefer. On an open coil unit it really does not make much difference. On a smooth top, Make sure it has a flat bottom, preferably dark, not shiny. On white smooth tops avoid aluminum as it leaves grey marks.
Jun 18, 2008 | Jenn-Air Cooktops
Elecrical hook-up for cooktop
Based on your description...it appears the Viking unit may NOT comply with UL and the NEC....but implies that some local Codes may permit the suggested connection...and it may indeed be permitted - if the unit actually draws straight 240 and does not require a neutral for 120 volts (some cooktops do need the neutral for 120 volt control switches...such as your Jennair). Code now requires that new 120/240 units that require the neutral (your Viking unit states that it does not) be a 4 wire assmebly....and your unit MAY be an exception to this requirement.
Under those conditions...then it more then likely CAN be connected as you (and Viking) suggest - black to black, red to red,green to white...and insure that the junction box is indeed well grounded to the supply bare ground wire - so that the metal flex will serve as a supplemental ground to the cook-top.The only other consideration will then be - IS the exisiting wire size and breaker that used to supply the Jennair correct for the new unit..? And if so - then you should be all set with your suggested hook-up...but without electrical nameplate data for both units for comparison...I have no way to determine that....both companies make several different models with different power supply requirements.
If the electrical data is compatible between the two units...then you should be all set as suggested - without having to rewire the cooktop.
Hope this helps...please follow-up if you need more details or have new information for me concerning this cooktop.
Feb 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Cooktops Logo
77 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
