Question about Ovens
GE Profile Cooktop Locked
Cannot unlock GE Profile cooktop stove. Control lock is on and cannot find manual in order to turn it off. New kitchen that is not compelted yet.
  • Anonymous Apr 05, 2009
    I have a PHP900DMBB GE Profile induction cooktop and somehow the control lock was turned on. I have repeated the steps i was told - hold it down for 5 secs and it should go off - did not work. I unplugged for a while in hopes it would"reset" - did not work. Now what??
5 Suggested Answers
  • 26 Answers
SOURCE: Replacing a glass cook top
You need to tell me the brand name and model # And I can help you
Posted on Jan 09, 2008
vanni7
  • 163 Answers
SOURCE: broken stovetop
Hi!!! With my experience some of them glass tops are very expensive check everywhere before you buy it and the labor to install one is high also.Good luck..
Posted on Jan 03, 2009
mrgrzz
  • 88 Answers
SOURCE: Water leaking on cooktop when using oven.
is there a fan for venting with this unit, if there is you will need to turn it on while cooking, it helps dissipate any steam or oil particles that move into the air, hopefully this will solve your problem, if you do have a fan and it is running, you may want to check the screen and clean it,as build up will cause the fan feature to not work as intended, thanks for your question,
mr.grzz
Posted on Jan 23, 2009
  • 360 Answers
SOURCE: ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Posted on Feb 25, 2009
espressonist
  • 1711 Answers
SOURCE: Hi, I need to know
No the burner have no ingiter ither piezo or electric just the gill and oven as you mention.
Burners need external light however they do have thermocouple protection when the fire goes out for safety.
Posted on Sep 17, 2010
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
We have a GE Profile cooktop in the house we bought. I found the manual from previous owners of house and it is a JP350. It has white knobs (4 large and one smaller one). I would really like to have...
Bonjour, j'ai un four GE Profile électrique acheté en 2006 et lorsque je veux me servir du fourneau, tous les boutons digitaux sur lesquels j'appuie donne comme résultat "LOC On". La plaque fonctionne toujours bien c'est seulement pour la programmation du four que j'ai un problème. Est-ce qu'il se peut que j'ai appuyé par mégarde sur quelque chose qui verrouille les commandes car jusqu'à dimanche dernier il fonctionnait bien? Comment régler ce problème? Merci à l'avance
Nov 05, 2010 | GE Ovens
Ge profile oven is in lock mode not able to turn it on , it says HOLD UNLOCK BUTTON FOR THREE SECONDS BUT THERE IS NO SUCH BUTTON, WHAT BUTTON SHOULD I HOLD DOWn?
Hold the "lock" button for three seconds.
This is the way mine works, yours is probably the same way.
Holding the "lock" button for three seconds changes it from locked to unlocked and ALSO from locked to unlocked.
Nov 16, 2009 | GE Profile JTP18 Electric Single Oven
mr.grzz
Jan 23, 2009 | Ovens
GE Oven not working
hi
you may need a new control board. if your stove is in warranty contact the manufacturer, if not and you are handy you can find a replacement online and install it yourself. just be sure to unplug the stove before you work on it. if you need help with this please contact me.
Mar 21, 2008 | Ovens
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
406 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
