Question about Samsung Color Fixed Security Camera Sod-14c
Need wiring map for RJ11 conector for Samsung SOD-14C camera
Would like to find an installtion manual for the SOD-14C or at least, the pin out (wire map) for the RJ11 connector. I would like to convert this to a barrel jack for power and a RCA or BNC connector for video.
  • 3 more comments
  • StrangerJLE Feb 13, 2009
    Please send your e-mail to jimmy.hpm@hotmail.com. I want to do the same thing. Thanks
  • airportbw Feb 20, 2009
    got the same problem samsung camera sod-14c and wanted to connect to the DVR with BNC jack and 12 volt DC from the power supply wanted to know what wire pin are for the camera and Mic found the 2 wire for the 12 dc those are the left 2 pins on the rj11 but dont know which one is for video any suggestion for this problem would really appreciate it to save me some money
  • Anonymous Feb 28, 2009
    I have the same problem. I cut the rj11 off. ai have a white and red wire and each wire has a bare wire shield. I know it is powered by 12vdc, and carries a video sig. Which wires do what, and what is the polarity?
    wdunbar01@gmail.com
  • Cesar Quant
    Cesar Quant Mar 09, 2009
    i have the same problem!!
  • Anonymous Mar 17, 2009
    i have the same problem as one of my rj11 connectors went bad so I need to replace that one
  • 3 Answers
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
  • satrianifnr
    satrianifnr Jun 12, 2012
    Here's the answer all...
    green wire : 12v dc
    clear wire : video ( + )
    wire around clear wire : video and 12 vlt ground ( - )
    you don't used the rest of wires . rest are audio .
My 3g isnt working how can i fix it
Check your sim card. If the connectors or only one connector is dirty or oxidised it could cause the trouble. You also could walk in a stroe from your providor and ask if they can help. They have spare sims to test if it is the sim or the phone.
Jul 05, 2014 | Samsung Security Cctv Sod-14c Soc-120...
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
How do you wire a RJ11 phone jack with cat6 wire??
I assume you are using this configuration to connect a phone and not data outlet.
The RJ11 connector is used for phones and the RJ45 is used for data.
The CAT6 cable has 8 wires and to wire this cable to a RJ45 connector 2 wires on the CAT6 cable are not connected.
Go to this site for a wiring diagram for RJ11 to RJ45.
http://www.google.com.au/imgres?q=rj11+to+rj45+wiring+diagram&hl=en&sa=X&tbm=isch&tbnid=4RlQiCWju6MukM:&imgrefurl=http://ps-2.kev009.com:8081/tl/techlib/manuals/adoclib/aixasync/asycomgd/port128b.htm&docid=zs9vggehEny1kM&w=966&h=680&ei=WWxCTpbYNeL9mAWkpLjVCQ&zoom=1&biw=1016&bih=511
Aug 10, 2011 | Computers & Internet
Say the system has 50 ft cablesfo the camers, but u need naybe 15 ft more that can u do?
as long as its cable run, should not be a problem. I went from 50 to 75 for my shop, works fine.but throw some e-tape around the connections.
Mar 19, 2011 | Samsung Color Fixed Security Camera...
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
Well good news and bad news if u just got shot ends easy cut end off and copy other end with new rj11 6 pin phone jack.. what im trying to do is give camera secondary 12v power and use the wire in the jack to splice into RCA type connector to work with my old dvr
Sep 12, 2009 | Samsung Color Fixed Security Camera...
Bushnell Northstar 78-8840 Pinouts
Here is a web site with all the manuals for Bushnell telescopes -- possibly the pin outs are described in the manual for your telescope?
http://www.opticsplanet.net/bushnell-warranty.html#manuals
Apr 10, 2009 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Mar 09, 2009 | Samsung Weather Resistant Security Camera...
Samsung survalance cam sod12c
check on the electronic board inside the camera, you will probably see a few condensator with a "-" on it, just follow the connection and your negatif wire will be connected to it...
cheers
Dec 20, 2008 | Samsung Color Fixed Security Camera...
Samsung Color Fixed Security Camera Sod-14c Logo
4,090 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
