Question about Dryers
I lost Lasko knob on side of windmachine 3300. It helps hold tilt
Do you have a replacement knob?
  • JJHuggins May 05, 2009
    I also lost one of the knobs on the side...need to source a replacement.
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Lasko Model 5154 ceramic heater
try your local radio shack dealer.
Posted on Dec 07, 2007
What do I do if a small wire came loose on the control knob?
Sounds like you may need to solder it back on to the switch contact
Jun 19, 2015 | Lasko 3300 Wind Machine Fan
My knob on my lasko fan fell off, How do I put it back on?
If the knob is still in tact it will have a shaped hole that fits on the post it came off of. Some knobs, but I am pretty sure not this one, will have a set screw on the side to tighten it down. I am sure it is just a push on compression fit.
Apr 09, 2014 | Lasko 20" Box Fan
I don't have a part # for the knob. It is for a Lasko fan. PN# for the fan is 203 5001. Fan Model 1338PH14. since the knob broke, the only way to turn fan on/off is with pliers. Home Depot does not...
often at good hardware stores. there will be a box or drawer with a variety of replacement knobs in it. these are generic knobs designed to fit a wide variety of things, so try and find the drawer or whatever. it may be in the electrical section or it may be with the oddball screws and nuts and things. It's there, but dont ask if they have a replacment knob for a lasco fan, just ask for a selection of replacement knobs Hope this helps, if it does please click the thumbs up
Jul 03, 2011 | Vacuums
Is there a means for a technically competent handyman to lubricate the bearings of the lasko wind machine 3300?
The fan and motor are both easily disassembled with a Phillips screwdriver and some gentle force to remove the blades. Try to use even pressure when removing both the blades and opening the motor housing. The only questions are whether to flush the existing lubricant out of the bearings and what to replace it with. If you know what to use it shouldn't be a problem. If anyone could suggest an oil or grease, please do.
Apr 03, 2011 | Lasko 3300 Wind Machine¿ Floor / Box...
I have a lasko model 5362. the lower control knob is cracked. i need a replacement. please advise.
That model is under recall. DISCONTINUE USE
Also models 5132, 5345, 5364, 5420, 5532, 5534, 5566. For recall information see:
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
Dec 03, 2010 | Lasko Heating & Cooling
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
How do you take off the spinning part off of a lasko fan?
Just hold the blade and use a sharp knife and cut the string. It's really not that hard!
Jul 28, 2009 | Lasko 3300 Wind Machine¿ Floor / Box...
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Dryers Logo
116 people viewed this question
Top Dryers Experts
