Question about Acer Aspire 5610-4648 Notebook
Configuration of my pc
I have a new laptop and it wont connect to the internet. We have wifi in the home and 2 other pcs run off this. It says it is connected to ZyXEL but wont let me actually connect ?????
  • 34 Answers
Does your network use a wireless key (aka wep) if so you may have the password entered wrong. You will still be able to connect but you wont have internet and may get the error "limited or no connectivity"
Posted on Jan 20, 2009
  • 741 Answers
In the bottom right hand corner of your task bar, move your mouse pointer over each item until you get to one that says Wireless. Click on the wireless icon and when the window open look at the bottom it will ask if you want to look at the wireless connections. Click on that and all of the wireless connections will be available. Find the one that is yours click on it and then click "connect". It may ask you for a WEP or WPA key which is the password to your wireless internet. Type in the password and you should be connected. If you have any questions/problems let me know.
Don't forget to rate this solution before you log out.
How do i print something from the ipad
1. Printer which can be connected using wifi 2. Mail the Same file to another PC or Mac which is connected to the printer 3. I cloud can be used so that if u have configured the same on ur office as well as home pcs or mac, u can take print out from the same
Dec 27, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Hi, till recently I was conneted to the internet (AOL) via cable connected to a NetgearDG834G v3 Modem router with no problems. Replaced PC with laptop (vista home premium) and connected via cable in the...
do your router modem got a wifi wire? or does it capable on wireless connection. try to use a windows xp not vista. it must be the problem. or configure it manually on your wireless connection in control panel. hope that helps!
CHARCOIS
Aug 09, 2008 | Computers & Internet
I purchased a sylvania netbook windows ce and wifi connectivity wireless moble internet device and i seem to not be able to get any internet service on it and i have 2 pcs that are wierless in my home...
Follow the steps on the first video:
http://www.digitalgadgets.com/mini-netbook.php
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 06, 2011 | Sylvania G-Netbook
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Connect Sprint PCS Sierra Wireless Aircard 402 home network??
Yes, you need to get in the router settings and disable DHCP in LAN configuration. That should do it. Also enable the ICS for the Air card. (Right click on Sierra Wireless icon, properties, advanced, check the box next to Allow others networks user to connect through this computers internet connection)
Sep 24, 2009 | Cell Phones
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Linksis wireless computer setup for WRT54G model
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
WIFI for Toshiba E750
If u use a WLAN access point, you should: 1. configure your wlan router to allow internet 2. choose "WORK" in the network connections configuration dialogs. and maybe you will have to configure the proxy server too.
Sep 11, 2005 | Toshiba e750 Pocket PC
Acer Aspire 5610-4648 Notebook Logo
417 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
