Question about LG WM2077C XL Front Load Stackable Washing Machine
Washer door switch
When starting the washer you hear two clicks then code de will show i opened the top lid found the door switch broken. the part number is 413-hs 6601er1004c 26/02/06 (i think its the production date).
  • 489 Answers
SOURCE: DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Posted on Apr 28, 2008
  • 489 Answers
SOURCE: door latch
DE error code is because there is a drain problem and it will not lock the door.  You will need to clear out the obstruction in the drain pump before operating the machine.  It is possible that the drain pump could be damaged from excess debris breaking the pump.  In that case, the drain pump will need to be replaced.
Posted on Jun 26, 2008
localwonder
  • 6784 Answers
SOURCE: my washer is not locking the door
HI. This is a Door Open error code.
Here are 4 reasons for this issue:
* The Door may not be all the way closed
* Loose electrical connections at door switch and pwb assembly.
* Door switch assembly is out of order
* Gasket on door may be creased in
Ok. You have stated that the unit is attempting to lock the door, but it is not locking. There are two click, then the error code illuminates the DE code. This is common when the control cannot initiate a door lock sequence. The cause will be a failed door lock mechanism, and it will require you to replace this mechanism asap, if possible. The actuator has failed. Replacing the door switch mechanism, will correct this issue.
Posted on Oct 19, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
  • 6277 Answers
SOURCE: Model WFT65A31EC washing machine. Problem
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on May 29, 2011
I got samsung washing machine top loader the start button it quite no sound by pressing and doesn't start the machine.
I had the same problem faulty lid switch..... So meaning when the lid is shut the washer thinks it's open.....I ended up throwing mine out too expensive to fix....
my Samsung washing machine was a recall but found out too late check their recall models you might get it fixed on warranty...
cheers hope this helps
Apr 21, 2017 | Samsung Washing Machines
Washer fills up with water but does not start to wash/agitate
if you don't hear the motor running you have a bad lid switch,if you do hear the motor but no agitation you have a broken motor coupling.
most likely you have a broken lid switch,close the lid,then open it around 6 inches,close it and open it a few times,as you do this if you don't hear a clicking sound the switch is bad,part number 8054980 and it's around 25 dollars.
http://www.youtube.com/watch?v=PZAbg9uftos&feature=BFa&list=PL946F2AC904989088
watch this video, when you click on it look down on the left side it will say replacing new style,click on it and it will show you your model.it will show you how to make sure it's the lid switch but if you don't hear any clicking when you open and close the lid the switch is bad,also if the lid is pushed in from putting the laundry basket on top of it open the lid and wack the center of the lid to pop it back up,i've done this before when the lid is dented in and this fixes the problem,the arm that's connected to the lid doesn't hit the switch correctly with the lid dented in but usually the switch is bad and needs to be replaced.
http://www.youtube.com/watch?v=MFsvLiuTniU
watch the first part of this video and it will show you how to open the top console,this is different from your lid switch this is just to get you into the top so you can change the switch.good luck,if you need anymore help let me know and i hope this helps you out
May 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 - will fill but no cycle or drain, can hear the timer running
Apr 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
LSQ9549LWO WHIRLPOOL WASHING MACHINE TOP LOAD NO SPIN @ RINSE CYCLE
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Aug 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is full but won't start cycle
This is a symptom of a defective lid switch. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. Please post back with your number if you need assistance in determing part numbers. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very simple repair that doesn't cost a lot. If you require additional assistance, please let me know. I hope this helps you.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
How to fix the lid sensor switch?
If you still require assistance, follow these instructions. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
I hope this helps you. If you require assistance in locating parts, or need further advice, please let me know.
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
LG WM2077C XL Front Load Stackable Washing Machine Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
