Technician failed to fix gadget where to complaint?
Cracked broken glass brought to cellphone repair shop to be replaced.lcd.everything working.when it was put all together it wont work or has no display.
bmwrider
  • 215 Answers
SOURCE: Broken LCD Display
You should find it easy to pull apart if you take your time and find all the screws. Just don't use brute force or a hammer:-) Maybe a friend can help you if you feel wary. Once the back is off be carefull there may be cables connected to it so don't get carried away. Often the LCD is lying on top of the remainder of the camera and sometimes it's attached the rear of the camera. You'll know as soon as you get it open. Find the screws retaining the LCD and remove them. You may find some adhesive tape holding the LCD down too. Carefully remove this and keep it.The LCD will have one, maybe two flat ribbon cables protuding from it. To disconnect these the sockets they are attached to will have either a tiny plastic flap across the top of the cable holding it down and if it's one of these then carefully pry the flap up with a thin blade. If it doesn't have a flap the you'll notice a different coloured piece of plastic rinning under the cable with very small protusions at each end. With a small screwdiver you should be able ease these protusions away from the socket. Do one end and then the other but don't push too far. This will loosen the cable and you can pull it out. You will probably find two standard type wires coming out of the LCD as well. If you're lucky they terminate in a plug which is easily removable. If not they will be soldered to a PC board. Do a rough drawing of the board and mark where which coloured wire is soldered. For a replacement you can try Fuji but if you think the cost is over the top take a look at Ebay and see if there's the same type camera as yours which is being sold for parts or repair. If you do find one make sure the LCD is intact and bid away on it. Ebay is a goldmine of spare parts and I've used it many times to get cheaper parts for myself. EG a cmplete camera with broken lens for less than Sony wanted for freight for the part I needed. If you don't find one wait a few weeks and one may turn up. When you get the replacement use your memory and put it all back together without ending up with a spare screw or two. Good luck. BMW
Posted on Jul 02, 2006
  • 84 Answers
SOURCE: LCD TV with broken screen, good picture??
You can have them repaired using a TV Repair guy but often it costs as much as a brand new plasma. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I bought a T.Sonic 610 (2GB) about a month ago.
Cannot be ordered - replacement only option
Posted on May 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: BROKEN LCD SCREEN!!!
Normal repair shop can't fix it
iRiver will not send you the screen
You must get the entire player replaced
Sorry, but this is true of nearly all Mp3 manufacturers.
This is the only answer I can give you, because it is the only truthful answer.
Posted on Jun 09, 2008
Agent Ken
  • 250 Answers
SOURCE: cracked screen LCD
Hello shaffycat,
Sorry to hear about the screen on your Sansa E250 MP3 player. It sounds like the Liquid Crystal Display screen has broken. It's possible that the damage is repairable but to be honest due to the high cost of electronic repair it may not actually be cost effective to do so.
You can contact SanDisk to get service information. They can give you a basic idea of what it would cost to get an estimate on repairs and the average cost. Their webite is http://www.sandisk.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 23, 2008
How to fix Samsung S4 cracked screen?
http://www.ifixit.com/Guide/Samsung+Galaxy+S4+Cracked+Front+Glass+Replacement/21843
Apr 24, 2014 | Samsung i9500 Galaxy S4 16GB Unlocked...
Garmin 660 broken screen
Its the LCD glass which has gone bad you cannot change it yourself,
Jul 07, 2008 | Garmin StreetPilot c340 GPS Receiver
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
I dropped my nokia 6303 and screen not working now. Phone still works but cant see who's calling. Can it be fixed?
hi,
yes it can be fix ,but unfortunately not by you..beacause its a sensitive case...go to a cellphone shop to repair your lcd connector first ,that lcd connector connects the lcd or glass display to main board of the cellphone ,if it is damage or lost of contact you cellphone display is not working...second try to replace a new and good lcd before going to the last option ,which is the display driver of the phone...the display ic is a small components that makes the lcd functioning..
the above solution must be doing by an expert mobile technician and its step by step procedure must needed to prevent bigger damage in your phone..
i hope it will help you ,thanks for trusting fixya..
Jun 19, 2010 | Nokia 6303 Cell Phone
Screen appears to be cracked but glass on the outside not broken.
Hi.
If the outside panel is intact, then the crack may be on the LCD panel, located beneath the protective glass panel.
If the Sat Nav is less than one year old, then the replacement will be done free of charge.
Contact TomTom at the number listed on manual to arrange repair.
Here the repair procedure : YouTube - TomTom Xl lcd replace
Jan 05, 2010 | Tomtom One XL GPS Receiver
Our daughters HP photosmart M637 camera's display looks like broken glass. She says she did not drop the camera but was scroling through her photos and all of a sudden the display window went blank and...
As you suspect, this simply does not happen unless the LCD panel has had a physical impact. The LCD units are stress tested when manufactured and the odd ones which crack "all of a sudden" would do so within a few months of manufacture and then get replaced under manufacturer's warranty. The broken glass which you see is the cracked LCD unit and it's behind an outer plastic protective cover.
The only way to fix it is to replace the LCD panel, but it's not a DIY job and repairs will cost more than the camera is worth. The M637 will only be about two years old but it was a budget model to start with so it would be cheaper to buy a fully functional used equivalent camera. There are even brand new models of similar or better specification which will be cheaper than a repair.
If the camera works "as is" then it may be better to put up with the fault until the camera no longer works.
Dec 07, 2009 | HP Photosmart M637 digital camera (L2455A)
Screen cracked and turned black, unable to use desk top the glass that you touch on top of the lcd screen is not cracked,its the bit underneath.
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Oct 31, 2009 | Motorola Mobility A1000 Cellular Phone
Broken lcd display on lg lx 260 cell phone. where to shop for parts.
I also need to replace a white-out lcd. I've shopped around, "Cellphone Shop", Cellphone Repair Shop", ect, roughly a hundred bucks. Tried E-bay, $25. plus shipping. Good luck.
Apr 16, 2008 | Computers & Internet
LCD display cracked
id put my **** in my *** and cough out a nut
1600$ i could pay a ***** 16 time to but a nut and lick
my booty hole
Dec 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung Blackjack SGH-I607
You can get a Samsung Blackjack I607 Window Lens at www.cellphone-repair-shop.com
Here is the exact link for the part: http://www.cellphone-repair-shop.com/GH72-30531A.htm
You can also send your phone to them and they will perform the repair for you.
Here is the link for the Samsung Blackjack Cellphone repair service they offer:
http://www.cellphone-repair-shop.com/Housing-Lens-Cellphone-Repair.htm
Nov 15, 2007 | Samsung Blackjack SGH-I607 Smartphone
23 people viewed this question
 Grubhead
Grubhead
