My Lennox gas fireplace won't light burner when switched on unless I open glass and break vacuum. I just replaced thermocoupler
  • 5 Answers
SOURCE: need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Posted on Jan 26, 2009
  • 188 Answers
SOURCE: I need ods pilot part no. 100701-02 and
Contact Master Parts, they may have the parts you need. You can contact them at 800-446-1446 or online at www.masterparts.net. Thank you
Posted on Aug 28, 2009
heatman101
  • 43501 Answers
SOURCE: my Lennox G10R03-110-1 heat unit, will not light
You have a pretty old Lennox there. The G-10's went out of production many years ago....
Since you have pilot and the thermocouple was replaced you will need to check and see if there is voltage going to the gas valve. You should have 24v AC across the two wires on the gas valve when there is a call for heat. If not then the limit switch or the high limit switch are cutting the power to the gas valve. You will need to reset or replace them.
If you have power to the gas valve then you have a
faulty gas valve and will need to replace that.
It if very possible that the gas valve has failed on a furnace the age of yours. That would be my first guess. But do check for voltage before replacing it.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
  • 3315 Answers
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Posted on Jan 02, 2010
  • 4736 Answers
SOURCE: hi i live in reservoir melb vic i have a old
The part you described is the heaters Control Valve for your Infrared Gas Heater. It is an expensive part to replace. If one is still available for your older unit.
You failed to mention where (what country you're in), but Vulcan has been popular in Australia for many years, So I'm assuming you're in Australia.
Below is a link to contact information for Vulcan in Australia, b region. Hope this helps you find a service technician.
http://www.vulcan.com.au/contact.htm
l
Posted on Jun 01, 2011
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I lit my gas fireplace and left the room. When I came back both the pilot and main burner were off. I figured my t-couple dropped out. Turned the valve to pilot, pressed the knob down, hit the ignitor and...
Pilot must have gone out along with main burner ,but it takes 30 secs to shut off would say you hit the ignitor at the wrong time to blow out glass . So you will need a new glass if broken , clean pilot and burner I would change thermocouple , then checkif gas valve is not sticking open . Maybe best to get local gas company to check this all out.
Dec 31, 2012 | Heating & Cooling
Water heater burner wont light
Problem is not thermocouple:
Thermocouple should be finger-tight plus 1/4 turn
Overtightening will short thermocouple against gas control valve, and solenoid switch will not open, and no gas will reach pilot once red button is released.
Tip of thermocouple has to sit in the pilot flame.
If pilot flame will stay on, then thermocouple is good.
Problem is not solenoid switch.
The gas control valve solenoid opens and closes gas supply to gas control valve.
On mechanical gas control valve, when you push down the red button to light pilot, then you are opening the solenoid and letting gas flow into gas control valve.
When heat is applied to thermocouple, a small electric current travels to gas control valve, and this causes solenoid to stay open.
If you extinguish pilot, then no current travels to gas control, and solenoid clicks off.
You can hear it click, and this is how you test it.
However, since you are getting gas to pilot light, then the solenoid is not the problem.
This leaves 4 possible problems:
1) Bad gas control valve thermostat.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Inadequate gas pressure. Call gas company.
3) Dirty combustion parts. Clean the burner with wire brush and water.
4) Clogged air intake on FV water heaters: Rheem FV gas water heaters have glass vial that will break if combustion is slowed by clogged air intake.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 06, 2012 | Rheem 40 Gallon FVR NATGAS Water Heater 6...
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
Gas fireplace wont stay lit- it is a sealed unit so can taccess the pilot or gas holes in the logs. is it safe to remove glass panel?
Yes, removing the glass is safe, if you do it carefully, so as not to break it. Put it well out of your way, after removing it. In fact, removing it is the only way to access and service the Pilot Assembly and the Burners.
If the pilot won't stay lit, there are several things that can cause this on a Direct Vent Gas Fireplace:
  • The direct vent on the outside of the house is block or clogged.
  • Wind is blowing back through the direct vent, blowing out the pilot.
  • Low gas pressure
  • A dirty pilot.
  • The thermocouple and/or Thermopile (part of the pilot assembly) has failed.
If you can provide me with the make and model number of your gas fireplace, I may be able to furnish you with an Owners Manual, that will help you to continue to troubleshoot the problem.
Hope this helped you.
Apr 29, 2011 | Heating & Cooling
I have a Marco gas fireplace model# 794019C. It is the millivolt pilot generator type. I first changed the thermopile and cleaned the spark ignitor to get it to light. I have checked continuity and...
Mike, I suspect that the problem you're having is not related to the new Thermoplie (Pilot Generator) you installed. Its with the Thermocouple. The clue was "Some of the time its hard to keep the pilot light lit". The Thermopile controls the opening and closing of the gas valve, when the wall switch is turned ON/OFF. The Thermocouple, is what keeps the gas valve open and pilot light lit all the time. If there's no flame heat on the Thermocouple, it closes the gas valve. Rather than replace it, you can try polishing it with some very fine sand paper, then wipe the tip with a cotton ball soaked in alcohol. If the Thermocouple is really pitted, don't attempt this. Just replace it. If you do replace it, when you make the connection to the gas control valve, finger tighten the nut, then tighten only 1/4 turn more with the appropriately sized wrench.
By the way, MARCO is no longer in business as MARCO Fireplace. It was purchased by Lennox Hearth, a division of Lennox Heating. And your model firsplace is no longer manufactured. If you continue to have problems with it contact Angie Parrish at Lennox via email angie.parish@lennoxhp.com.
Hope this helped you solve the problem. Please be kind enough to rate my response to you. Thanks and have a good day!
Mar 25, 2011 | Heating & Cooling
My Lennox G10R03-110-1 heat unit, will not light the burners even though the pilot light is lit, and the thermocoupler was just replaced today
Heatman101
Nov 29, 2009 | Heating & Cooling
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
