Question about NetGear RangeMax WPN824 Router
Netgear WPN824 wireless router
I've just setup my new wireless router and the signal is appalling and I can only connect at 54mbps instead of the max 108mbps. Also, the signal is constantly dropping out, even when I'm connecting wirelessley right next to the router. At my PC end I'm using a Netgear WPN111 wireless USB adapter so I would expect to get maximum performance. When connected directly to the router via an enthernet cable the performance is fine, and at 100mbps as expected. Can anyone help?
    President:
  • 2,961 Answers
There is no reason why you shouldnt connect at 108 mpbs, so there are only a coulple of things you can try, the first is to change the channel that your router transmits on within the router settings, although this should automatically be done by the router when it comes up against any interference. Secondly try the adapter in a different usb port as USB 2.0 should be used and the port may not be recognised as a high speed port. Double check the router connection transmition speeds is set at 108 mbps; as it would also be able to transmit at a lower speed of 54 mbps so as to be backward compatable with 54 mbps adapters
Posted on Jun 30, 2007
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
I can't connect to internet wirelessly, though my
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | NetGear RangeMax WPN824 Wireless Router...
How do i change my router's nat type 3 to nat type 2 for my ps3.My router's name is Netgear Range Max wireless router WPN824.and my internet provider is Qwest DSL.
Instead of changing the NAT type, it is effective to forward ports on the router for your PS3. Perform the steps as mentioned in the below link:
http://www.portforward.com/english/routers/port_forwarding/Netgear/WPN824/PlayStation_Network.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
Everytime I want to use the internet I have to plug in the ethernet cable from the router- WPN824- and go the the 192.168.1.1 address and setup the wireless setting. Then I can disconnect and use my laptop...
Netgear routers are notorious for this. The firmware on the unit just loses connection. In order to fix this, you have to make sure that you have the latest firmware.
There are several version of your unit. go to the following page and download the firmware and update it to the latest non-beta release.
http://kbserver.netgear.com/products/WPN824.asp
Aug 04, 2009 | NetGear RangeMax WPN824 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lost setup DC
The router is compatible with any operating system. You don't need to use the CD that came with it to setup the internet connection. Just open the router's setup page by typing http://192.168.2.1 on your browser. There you can see the automatic setup.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Netgear range max keeps dropping signal
Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
Jan 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Router Logo
204 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
