Question about Starbucks Barista Quattro Coffee Maker
12 cup barista will not pump water through to the pot
My 12 cup barista stopped pumping water through to the pot
I fixed the problem. Just send me $9.95 and I'll tell you how I did it. This is my Premium Plan!
Thanks,
Kenny
Posted on Jan 21, 2009
  • gkpohl Apr 24, 2011
    send me 14.95 first and I will give you the specifics
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Oct 16, 2014 | Bunn CWTF15
Need lid for starbucks barista aroma grande 12 cup carafe.
The exact same lid is on the Wolfgang Puck WPTPCM010 coffee maker. (It's exactly like the Starbucks one - same size & fit.) Call (800) 275-8273 and order part # WPTPCM010-6; the product description is "LID FOR CARAFE". It will cost you $4.99 + 5.00 shipping. My Starbucks coffee pot works PERFECTLY again. Just make sure that you put the lid on the carafe correctly before you use it, since the seal is new.
Mar 30, 2011 | Starbucks Barista Quattro Coffee Maker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Inside of carafe changing color -- is it still safe to use? (have been using it for 6 years)
The owners manual with our "12 cup Barista aroma grande" recommends cleaning the unit with a cleaner / descaler that you can buy at Starbucks, or 6 cups of a 50-50 vinegar-water solution, or 6 cups of a 50-50 lemon juice (no pulp!)-water solution. You have to then run a whole pot full of water through to rinse the unit. My wife cleans it once or twice a year with the Starbucks cleaner, and the staining comes off the inside of the pot (you may have to do it more than once with a 6-year deposit). The coffee also tastes better afterwards - less heavy and oily, more crisp and flavorful.
Feb 11, 2010 | Starbucks Barista Quattro Coffee Maker
I have a cuisinart 12 cup thermal, it turns on as if it was going to make coffee (lights only) but no water runs through the pot. Grinder still works. Any help arreciated.
The water line may be clogged from calcification. Or the water pump may be going bad. If it is still under warranty, check with Cuisinart.
Jul 08, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
After filling my Mr. Coffee to the 12 cups limit, turning on the machine...2 1/2 cups of water do not make it to the pot. There is NO water on the counter but the poor thing is steaming like a locomotive...
Hi, My husband found the problem and fixed it. Something had fallen into the water reservoir and was small enough to block the pump. My husband extracted it, now all is well. the Coffee Maker is fine now.
sincerely,
chalice (a.k.a. HolyGrail56)
Aug 29, 2008 | Mr. Coffee FTX24 12-Cup Coffee Maker
Water heats up but is not delivered to basket
This may not help but doesn't cost much to try-
Make sure all water is out of the tank and dump a cup of cheap vinegar into the tank, turn it on until you hear some activity and then turn it off and ignore it overnight.
Turn it on in the morning and let the vinegar pump (hopefully) through and then run a pot or two of water before you try to make coffee.
There is a crappy plastic-body & ball valve in the line that is the first victim of lime deposits.
Once that little valve is stuck, it won't pump.
Plan on getting another coffeemaker in 3 or so years when another non-user replaceable part, the bimetallic thermal switch gets tired and it then takes a hour or more to make a pot of coffee.
Jul 04, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Need to replace water carafe to Starbucks Barista Araoma 12-Cup Coffee Pot
I have the same problem, but have not been able to find a new carafe, so far.
Jun 10, 2008 | Starbucks Barista Quattro Coffee Maker
Starbucks Barista Quattro Coffee Maker Logo
320 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
