Question about Dryers
Dryer Tripped the fuse box And now just displease cold E9E
  • 3 Answers
Unplug or look 4 reset button check braker it must be = in amperage to dryer
Posted on Jan 08, 2013
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: breaker was inadvertantly tripped by person which shut dryer off when reset breaker dryer wont work
You have to test the voltage to verify that the breaker did reset. Unplug the dryer, and verify that you have 240 volts at the receptacle
Posted on May 31, 2009
TheMobilian
  • 8220 Answers
SOURCE: My dryer, estate EED4400WQ0 will
Remove the dust cover and the filter chute. See the fuse?
small white component to the right of the blower wheel below:
I use a shop vac to clean out the dryer.
I always take the drum out and clean her up. I use zoomspout oil on
the idler and rollers because it is safe for dryers and heaters too.
I have a service manual and videos of how to get into your dryer HERE
Posted on Feb 10, 2011
Jahn27
  • 1554 Answers
SOURCE: I need to find the fuse box in my lg dryer- my
Dryers do not have fuse for the lamp and the controls. Make sure first that the dryer is getting power from the outlet. If yes but the dryer won't work and the lamp won't turn on either when the door is open, the problem is with the door switch which has three terminals, COM, NC. and NO. The COM terminal is where the wire from the power cord connects to, The normally close terminal NC is where the lamp is connected while the normally open terminal NO is where the dryer controls, motor and heating circuits are connected to. The lamp should at least turn on when the door is open as long as the dryer is plugged in. Replace the door switch if the new lamp doesn't turn on at all.
Please indicate explicitly the exact model number of the machine should you need further advice. You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice.
Posted on Jul 09, 2011
tbirdfan1
  • 3051 Answers
SOURCE: My dryer will not start?.....nothing tripped in
Hello there and thank you for choosing fixya
You will need to test the thermal fuse and see if it is bad. It should read closed for continuity. If it is open, check the vent and see if it is cloged or kinked. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. How To Check Continuity With Ohmmeter
Read more: http://forum.appliancepartspros.com/dryer-repair/277220-dryer-wont-turn.html#ixzz1U5vnbtDk
Posted on Aug 04, 2011
Testimonial: "Thanks fast response "
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Wont heat up
Good Morning Johnnie, thank you for your post!
Often when a dryer no longer heats, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and one also may have tripped. Typically, the heater of a dryer requires 220 to 240 volts to operate. If none of the tips above solve the issue, then it could potentially mean a number of other things: defective cord, a wiring failure, faulty heating element, or control board. Which in the case, I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Sep 10, 2013 | Frigidaire Dryers
Buttons, sounds, lights all go on but the dryer will not dry
Hello toofdr - Often this occurs because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn on but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My dryer is blowing air but it is not getting hot or drying clothes
either the fuse for the heat portion of the dryer( in your fusebox or breaker box) has blown or been tripped, or you have a broken heater element in the dryer. the most common is a tripped or blown breaker or fuse. check the breaker box/ fuse box first.
May 01, 2010 | Kenmore Dryers
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
My dryer is blowing cold air and not drying at all
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 03, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
