Question about Garden
My husqvarna iz4819 kawasaki 19 hp engine zero turn mower approx 700 hrs. runs fine idle but on full power after it gets hot, it starts to purge and lose power
  • 109 Answers
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Posted on May 03, 2009
  • 203 Answers
SOURCE: Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Posted on Nov 15, 2009
huffman49
  • 235 Answers
SOURCE: 19 hp kawasaki carb acting up
sounds like the carb is gummed up from the old gas you will need to clean and rebuild te carb(this is a easy job)...good luck
Posted on Apr 11, 2010
Testimonial: "Thanks. I came to same conclusion but because of limited ability in this area(I'm an electrician by trade)I wondered if I could cheat & spray it out?"
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
  • 146 Answers
SOURCE: Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Posted on Jul 12, 2010
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have a 2005 Dixon zero turn mower the motor is hard to turn over but once it starts turning it turns fine when the motor starts it will only idle and not accelerate it has a 14.5 hp Briggs and Stratton...
sounds lie it's starving for gas.
Does this engine have a fuel pump or is the gas gravity fed???
Some engines this size do have fuel pumps.
I'd also take the bowl off the carburetor and check the Jet.
Aug 10, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Apr 27, 2012 | Husqvarna Zero Turn Mower Z5426
It shouts off after it get's hot. 1 to 3 hrs of running time. I think it maybe the coil packs. It will restart but has a miss.
That is a good call! You can test for spark the next time the mower wont start and confirm it.
You should remove the engine cover and see if the airpath is blocked with dirt, debris or even animal nests. When you are there you can swap the coil(s) out. You should find out about proper gap specs for the style coil you are replacing by looking it up either on the Husq or Kawi website. Whichever is more specific.
Good luck and be carefull.
Jul 30, 2010 | Husqvarna 60'' Zero Turn Lawn Mower 34hp...
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Apr 04, 2010 | Garden
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
